Thread: Exhaust leak while in drive and WOT?
Results 1 to 13 of 13
  1. #1 Exhaust leak while in drive and WOT?
    Denver
    I have what sounds EXACTLY like an exhaust leak. I can only hear it when under heavy or WOT and while driving. I can't reproduce it in neutral and WOT (until it splieks the rev limiter). It sounds like my old lawnmower when the muffler rusted off. It's a loud ticking noise.
    I've inspected my exhaust system, manifolds, cat, muffler etc, and can't find nothing. I live in a very ariod environment so I have no rust at all.
    I've also checked suspension, bearings etc. I'm as suare as I can' that it's exhaust.
    It's a little louder from the driver side and also sounds like it's coming from the engine area.
    Any ideas?
  2. #2 Re: Exhaust leak while in drive and WOT?
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    What exhaust configuration do you have?
    Edit: Notice you have manifolds so I assume stock.
  3. #3 Re: Exhaust leak while in drive and WOT?
    Denver
    All stock (exhaust), 138k miles.
    During the exhaust notes, the car performs perfectly. I pulled all of the plugs and all are pristine (plus I wanted to make sure one wasn't loose and causing the exhaust leaks). No chugging, no misfires, nothing else weird.
  4. #4 Re: Exhaust leak while in drive and WOT?
    gasket from the dp to catback?
  5. #5 Re: Exhaust leak while in drive and WOT?
    Denver
    There is no gasket issue. It's perfect (between the two flanges).
    There is a flex joint between the DP to cat (past the flange, cat side) - it seems to be in tact, but I can't tell.
    I'm wondering if excessive engine movement (stock upper mounts, very slightly rotted) cause the engine to twist under load and open the flex joint.
    I can't see any damage with the joint - but I also can't see if when the engine has twisted (like under load).
    I'm stumped - I may record and post as it's very annoying.
  6. #6 Re: Exhaust leak while in drive and WOT?
    seafoam it and you'll be able to see where it's leaking at
  7. #7 Re: Exhaust leak while in drive and WOT?
    The Boss Iceman6669's Avatar
    Jun 2011
    Thats the TRUTH!!! I just seafoamed mine and it smoked like a jonesing crackhead.
  8. #8 Re: Exhaust leak while in drive and WOT?
    Denver
    The seafoam idea was a stroke of genius.
    My car billows smoke from the rear exhaust manifold (of course).
    My plan is to pull it this weekend and see what I can see. I can always weld it back depending on what I find. I can't tell if it's from the mani itself, a gasket or what.
    Any advise/infpo regarding pulling the back manifold? How long does it take etc?
    It looks like something I can knock out over the weekend.
  9. #9 Re: Exhaust leak while in drive and WOT?
    Easiest way to pull the manifold is to remove the downpipe and wiggle it out the tunnel hole from below. If needed lower the subframe 2-3 inches at tha back to give you more room.
    Beyond that.. a deep ball pivot snap on socket with a long extension and air tools is the easiest way I've found to pull the bolts.
  10. #10 Re: Exhaust leak while in drive and WOT?
    Denver
    I don't have air tools (worth a crap).
    I assume you access the mani bolts from above, or is it easier from below after you remove the DP (with a real long extension)?
    I'm going to put it on stands tonight and check it with Seafoam again. All I could confirm last night was that it was coming from the area between the back of the engine and firewall.
    I don't know for sure that it's a cracked mani - it might be something with the DP or....? I'm going to look at it from underneath and see if I can better pinpoint the source.
  11. #11 Re: Exhaust leak while in drive and WOT?
    you can get a new flex welded in last time i did that i got new exhaust from the cat back and all together it was $150
  12. #12 Re: Exhaust leak while in drive and WOT?
    Denver
    The car has almost 140k miles on it - I just bought a new cat.
    The flex connection had completely failed. I will post a pic later - the interior portion (a sleeve) has come off.
  1. Loud exhaust leak!
    By cameron92 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2011, 02:59 PM
  2. Exhaust Leak at Startup
    By jdeslich in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2011, 08:13 AM
  3. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
  4. exhaust leak
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2009, 10:31 AM
  5. Need help with an exhaust leak
    By thenervemann in forum General Tech Discussion
    Last Post: 04-26-2009, 09:28 PM
