I have a 04gtp comp g and the ac just runs when it wants to what could be my problem? And what is the easiest way to take the dash apart, mainly the side panel to console? Any help will be greatly appreciated .Thanks I'll try not to let you down!
Hey y'all new here, have a problem with my 04 gtp comp g, the ac switch works when it wants to, blows cold air, heat,I can hit a bump and it will work,or it will cut off, I have wiggled all the wires and connectors that I see, now it won't work at all. So what could be my problem? And hopefully someone has a solution? Any and all help will be greatly appreciated Thanks from the great state of georgia!
The fan,when it decides to blow it's ice cold
Move/merger.
