Thread: Oil pan replacment
Results 1 to 11 of 11
  1. #1 Oil pan replacment
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    Is it as straight forward as Im hoping just unbolt new gasket and done or is it going to be 10874834738 x's harder than it has to be. A link if theres a writup would be cool but more or less just hopin for input.
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  2. #2 Re: Oil pan replacment
    gotta lift the motor up to do it, there is not enough room to get to all the bolts and get it out.
  3. #3 Re: Oil pan replacment
    Oct 2008
    IL
    Damn. So were talkin qwite the project then?
    Whoever owned my car before must have checked a curb and left the scuff cuz theres some rust workin at it pretty good.
  4. #4 Re: Oil pan replacment
    you could always clean up the rusty area with a scotch bright pad and paint the area with POR (paint over rust) paint, it stops rust in its tracks.
  5. #5 Re: Oil pan replacment
    Oct 2008
    IL
    I was actually taking that route lol. NOT the POR way tho wayy to expensive. I just got Krylons rust eliminator stuff. Ill clean it up reall good and put a few thick coats on and i think it should be good.
  6. #6 Re: Oil pan replacment
    i think you can get pints or quarts for under 30 bucks,(you'll find something else to use it on down the road too)
    por is the sh1t tho, my brother painted the his whole frame and under body on a 85 Chevy pick up truck and it looks like the day he did it, and that was like 8 years ago. once you put it on it never comes off, not by itself anyway.
  7. #7 Re: Oil pan replacment
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    you can also get it done by dropping the subframe. depending on your tools and work environment, (i.e. my apartment parking stall) this may be a little easier..
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  8. #8 Re: Oil pan replacment
    Oct 2008
    IL
    if your re spraying it year after year, that means moisture is getting to the rust area, and causing the paint to bubble or peel or flake off,(and continuing to rust) with por that never happens again, it seals the rust and never lets air or moisture to get to the area again, thus preventing the rust from getting any worse than it already is.
    don't sand it all nice and smooth either, wire brush it or scotch bright pad, (leave it rusty, remove anything loose) clean the painted areas around it and paint it on, that's it, very little prep work.
    from what i've been told por was originally invented to coat battery trays, its acid resistant and all that good stuff.
    Oh I havent sprayed it yet. Just bought the paint... Your really making me thinking just POR it and never worry again...
    Quote Originally Posted by Jakegday View Post
    My tools are limited to the set I got for auto in Highschool and I got my drivway to work. Id MUCH rather replace it than POR it but thats cash I dont have for sure right now. Im still looking for a decent shop for my LIM that wont rape me on price
  9. #9 Re: Oil pan replacment
    Ohio
    its a pain in the ass. i started the project at 4 pm on a saturday and ended at 745am sunday morning....with about 3 hours of ****ing around (eating and what not) no sleeep though
  1. Cat back replacment (How to remove)
    By mgolin in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-20-2010, 03:31 PM
