Thread: ABS warning light
Results 1 to 5 of 5
  1. #1 ABS warning light
    Apr 2008
    My abs light and trac off light came on and im wondering is that just the sensor or what would i need to fix that? The lights arent on all the time but they eventually come on. Also My o2 sensor went out a while ago and the service engine light is still on after i reset everything.
  2. #2 Re: ABS warning light
    Oklahoma
    For your abs and trac light, you probably have a wheel hub gone bad. Well not the hub itself, but the sensor that is build into the hub.
    If you still have an SES light on after replacing the O2 sensor and resetting everything, then you probably still have a code stored. Its either from the O2 sensor and did not clear or there is another issue setting a new code.
  3. #3 Re: ABS warning light
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    Quote Originally Posted by BankRupt View Post
    I have the SAME problem. Drives me nuts. Im getting a whole new break setup, and im hoping this may solve the problem. I doubt it though
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  4. #4 Re: ABS warning light
    Barksdale AFB, LA
    Getting it scanned by something that can read ABS codes (normal scanners can't) will tell you what has failed that is causing the light. If it's a wheel speed sensor, it'll tell you which one.
    2009 Subaru Impreza WRX STI
  5. #5 Re: ABS warning light
    GTX Level Member webracin's Avatar
    Arkansas
    Hey guys, we do have a "HOW TO" section in the upper right hand corner between the "Local Chapters" and the "Time Slips"....There is lots of good information there, for instance...
    http://www.grandprixforums.net/abs.php
    webracin
    2001 Grand Prix GTP
    ZZP HUB 3.2 3.4, ZZP 8 Rib conversion, JC 3" DP Gen 2 cat & U-bend Delete, Accel Super Stock 8mm wires, DHP 1.5, 180* Thermo, Throttle Spacer, SS Intercooler, ZZP Fuel Rails, SLP CAI w/K&N Cone, Dynomax cat back, ZZP Tranny.
    2000 Grand Prix GTP Daytona K&N, Flowmasters
  1. Change Oil Soon Light
    By thermanlee in forum General Tech Discussion
    Last Post: 04-29-2009, 08:47 AM
  2. help... my ses light is on
    By kingd44 in forum General Tech Discussion
    Last Post: 03-07-2008, 09:45 PM
  3. Tornado Warning!!!!!
    By 3800SE in forum Off Topic Discussion
    Last Post: 03-07-2008, 08:21 PM
  4. Head Light/Tail Light Covers
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:38 PM
  5. warning points system
    By 3800SE in forum Forum Bugs/Suggestions
    Last Post: 01-04-2008, 07:36 AM
