Thread: Ic pump,what brand/kind are you using?
Results 1 to 12 of 12
  1. #1 Ic pump,what brand/kind are you using?
    Jul 2010
    Houston, Texas, United States
    I'm curious to hear what brand /kind of pumps you guys/gals are using.
    Thanks for your time.
  2. #2 Re: Ic pump,what brand/kind are you using?
    bosch.
    bill will say get the meziere.
  3. #3 Re: Ic pump,what brand/kind are you using?
    Minnesota
  4. #4 Re: Ic pump,what brand/kind are you using?
    Portland Oregon
    GM pump on my ssic setup
  5. #5 Re: Ic pump,what brand/kind are you using?
    Feb 2009
    flintnasty MI
    Small GM bosch pump, get them all day for $10 bucks from the junkyard... never really knew why people dont use these more often.
  6. #6 Re: Ic pump,what brand/kind are you using?
    GT Level Member RegalGS98s's Avatar
    NJ
    Windshield washer pump, or what pump from GM vehicles? I'd think the windshield washer pump wouldn't flow enough GPM.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  7. #7 Re: Ic pump,what brand/kind are you using?
    Donating Users
    MA
    Meziere
    1998 Intrigue - Parted out
    2008 G8 GT - Heavily modded
    2016 WRX STi Limited - Bolt-ons
  8. #8 Re: Ic pump,what brand/kind are you using?
    Minnesota
    Quote Originally Posted by intrigue98 View Post
    Meziere
    Not that more flow isn't better but isn't 20 GPM a little overkill?
  9. #9 Re: Ic pump,what brand/kind are you using?
    Jul 2010
    Quote Originally Posted by Pure2sin View Post
    Lol I love that mine flows 800gph bro lol.
    Per minute you sure?
  10. #10 Re: Ic pump,what brand/kind are you using?
    Donating Users
    MA
    Yes the meziere pump I have flows 20 gpm. No, its not overkill. The only supporting reason to that is I have zero knock, on a 3.0, and with advanced timing with the stock cam. If the pump was flowing too fast then the intercooler/fmhe would be heat soaking and not allowing me to get those results.
  11. #11 Re: Ic pump,what brand/kind are you using?
    Minnesota
    I have not dropped pulleys yet but I will have to see how well my pump will work.
  12. #12 Re: Ic pump,what brand/kind are you using?
    SE Level Member kygtp's Avatar
    Oct 2008
    Cincy
    FlowJet. I have had mine for several yrs with no issue. 5 GPM is what it runs at.
  1. One of a kind '02
    By RegorHtims in forum Off Topic Discussion
    Last Post: 03-30-2011, 11:52 PM
  2. Ram Air (1 of a kind)
    By Mikey in forum Visual/Body Modifications
    Last Post: 06-13-2010, 07:21 PM
  3. what kind of mpg are you getting?
    By PolishedandWaxed in forum General Tech Discussion
    Last Post: 09-16-2009, 05:36 PM
  4. What kind of car is this?
    Last Post: 03-09-2008, 11:57 AM
  5. what kind of oil?
    By s1795so2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2008, 07:37 PM
