Thread: Water Pump
Results 1 to 9 of 9
  1. #1 Water Pump
    SE Level Member blaqdiamondz46's Avatar
    Nov 2011
    Savannah, GA.
    Any suggestions? Installed new water pump on 2001 Grand Prix SE V6!!! Still leaking!!
  2. #2 Re: Water Pump
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    im assuming you put a new gasket on?
  3. #3 Re: Water Pump
    Jul 2011
    Michigan
    and wrong section by the way
  4. #4 Re: Water Pump
    Jul 2011
    Michigan
    did you clean the mating surfaces? did you tighten it enough? gotta have more infor man.
  5. #5 Re: Water Pump
    did you put thread sealant on the 4 large bolts? they go right into the water jacket of the block and will leak if not sealed.
    and the matting surfaces need to be clean, like scrapped down with a razor blade clean, no old gasket material can be left on.
    i put my new water pump gasket on dry, no rtv at all and its holding fine.
  6. #6 Re: Water Pump
    Jul 2011
    Michigan
    ^^same, but i also didnt put thread sealent on and its also not leaking.
  7. #7 Re: Water Pump
    my bolts came out all gunked up from the old sealant, so i cleaned mine up and resealed them. better safe than doing it 2 times.
  8. #8 Re: Water Pump
    Jul 2011
    Michigan
    true
  9. #9 Re: Water Pump
  1. Water Pump
    By blaqdiamondz46 in forum General Tech Discussion
    Last Post: 11-11-2011, 03:29 PM
  2. Water Pump???
    By armyrebel03 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-12-2011, 11:26 PM
  3. Water Pump Help
    By thewaitinggame in forum General Tech Discussion
    Last Post: 02-18-2011, 07:57 PM
  4. Water Pump
    By carl06GT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 07:58 AM
  5. Water pump ?
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-10-2008, 01:21 PM
