Thread: What mount should I get first?
Results 1 to 5 of 5
  1. #1 What mount should I get first?
    Donating Users kyle91's Avatar
    Jun 2011
    Michigan
    Hey guys my funds are a little short and I believe I need to replace some mounts because I think I can here my downpipe hitting at wot throttle shifts. Which should I get first: the upper mounts, lower motor mount, or trans mount? And will solid rubber mounts be fine or go with polys? And can someone explain the "vibration" a bit about the polys?
    current mods: DIY FWI, res & u-bend delete, SD headers mated with custom 3in downpipe, 2.5in catback with turbomax muffler, autolite 104s, 180 t-stat, poly mounts, can tune, 3.4 mps
    soon to be mods: NIC cam, possibly dna springs
  2. #2 Re: What mount should I get first?
    Feb 2009
    flintnasty MI
    if you are getting headers.. hold off on getting any mounts just yet. Depending on what headers you get, you may want mounts that push the motor back or forward.
  3. #3 Re: What mount should I get first?
    I'm assuming if your downpipe is hitting that you have an aftermarkdet pipe or headers?
    Free: take a look at the center of your sway bar, does the point aim up or down? If up, remove the endlinks, and center bushings, take the bar out, flip it over so that the point aims down and reinstall it. TIP: lowering the subframe 2-3 inches in the back will help you get the center bushing bolts much easier and get the bar in and out.
  4. #4 Re: What mount should I get first?
    Jun 2011
    Michigan
    yes i have a zzp 3in downpipe and i'm going to headers and a custom made downpipe for em so like darkhorizon said, i think i might hold off to see how the fitment goes. i think i might do the sway bar mod just to allow more clearance any way.
  5. #5 Re: What mount should I get first?
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    what does that sway bar mod do?
  1. Multikit/Mount Kit to mount EQ?
    By iceman977th in forum Audio, Security & Visual Electronics
    Last Post: 03-25-2011, 01:59 AM
  2. mount gps
    By macey43 in forum Audio, Security & Visual Electronics
    Last Post: 12-22-2010, 09:42 PM
  3. How did you mount your SD lip?
    By machinegunsquid in forum Visual/Body Modifications
    Last Post: 10-05-2010, 07:54 PM
  4. Where should I mount my amp?
    By gpgt in forum Audio, Security & Visual Electronics
    Last Post: 04-22-2009, 06:35 PM
  5. vent mount
    By gotboost3 in forum Visual/Body Modifications
    Last Post: 12-05-2008, 05:59 PM
