Thread: New here and need some help
Results 1 to 5 of 5
  1. #1 New here and need some help
    SE Level Member Max's Avatar
    Jul 2011
    IL
    Hey im new to this forum and have just got a 97 grand prix... i was wondering about a few things first thing is i was wondering why when i turn off my lights they stay on when the car is running. And the second thing is my ac is not working and its a killer after work from the car sitting in 90 degree whether all day for some reason it looks like the fan clutch is not engaging or something like that is there common problems with that. Any help would be greatly appreciated.
    1997 Grand Prix 3800 SE
  2. #2 Re: New here and need some help
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    The car has a photosensor (light sensor) that turns the lights on when it becomes dark.
    The radiator fans are electric, they do not have a clutch. The AC compressor has a clutch. Does the AC system blow somewhat cool air or just ambient temp air?
  3. #3 Re: New here and need some help
    pull the DRL fuse if you dont want the lights to stay on.
  4. #4 Re: New here and need some help
    Jul 2011
    IL
    ok i will try that for the lights thanks for the tip.. and yea im sorry that is what i mean the ac compressor clutch will not turn on if i turn on the ac and i replaced all the fuses that did not work then i tried another relay and that did not work so im not sure what is happening with the ac...
  5. #5 Re: New here and need some help
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    Probably bone dry of freon and needs to be recharged
