Thread: removing valve covers?
Results 1 to 15 of 15
  1. #1 removing valve covers?
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    Ok wtf?!?! I can't remove the front valve cover cuz that stupid piece that holds the dogbone is in the way! I removed two bolts and it won't come off still! Can anyone tell me how to get that stupid piece off?
  2. #2 Re: removing valve covers?
    the ICM/coil bracket has to have the s/c belt removed, s/c belt tensioner, then three nuts then the tensioner will move.
  3. #3 Re: removing valve covers?
    Nov 2010
    Illinois
    Ah. So there's a nut I can't see cuz of that stupid tensioner. Do I just need to remove the pulley on the tensioner?
  4. #4 Re: removing valve covers?
    GT Level Member redgtp97's Avatar
    IL
    yes, the third nut is on the pulley
  5. #5 Re: removing valve covers?
    Nov 2010
    Illinois
    Son of a biscuit. Honestly I only looked at it for 10 minutes but it pissed me off cuz I thought it would come off quickly lol alright well no biggie. Ill remove the pulley tomorrow and pull the cover off so I can replace gaskets and paint my covers
  6. #6 Re: removing valve covers?
    no its not.
    its behind the tensioner nut which holds the tensioner to the icm bracket.
  7. #7 Re: removing valve covers?
    Nov 2010
    Illinois
    Ok and how do I remove that? I don't get much time so I need to know so I can do everything quickly.
  8. #8 Re: removing valve covers?
    13 mm nut sounds right.
  9. #9 Re: removing valve covers?
    Nov 2010
    Illinois
    Yeah I figured that or 15. Ok sounds good. Thanks guys
  10. #10 Re: removing valve covers?
    Welcome to the W body world. W stands for worst to work on.
    go take a look at a Bonneville, Park Ave or Riviera. Front cover comes off in under 30 seconds for any parapalegic.
  11. #11 Re: removing valve covers?
    Nov 2010
    Illinois
    Lol thats a good one. Try working on a 95 chrysler cirrus with a 2.5 and doin the water pump. Worst ever
  12. #12 Re: removing valve covers?
    worse than a quad 4 water pump, that's driven by a 9 foot timing chain?
  13. #13 Re: removing valve covers?
    GT Level Member 99GPGTP's Avatar
    Rome GA
    x2. thats a stupid design. quad 4 only had a few years that the wp would unbolt from the back side and was splined to the gear.
    99gtp 3.4"on ported m90, zzp 1.0 pcm, speeddaddy headers, stock mufflers w/cat and res delete,104's,FWI,180* stat, exhaust ported heads,Dog bones flipped, 18" 350z wheels
  14. #14 Re: removing valve covers?
    Nov 2010
    Illinois
    anything that requires you to remove the engine mount and go up and down with the vehicle and motor separately is a huge pain in the a$$
  15. #15 Re: removing valve covers?
    Rome GA
    like timing chains in a 2002-2006 v6 altima or 2004-2008 maxima
  1. Removing Valve Covers
    By kcfalcon2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-14-2010, 11:04 PM
  2. Valve covers!!
    By Ttypel67 in forum General Tech Discussion
    Last Post: 06-10-2010, 10:51 PM
  3. rwd l36 valve covers fit fwd l36
    By nascartech in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2010, 02:52 PM
  4. zzp valve covers
    By rodman in forum Turbo
    Last Post: 08-30-2009, 04:20 PM
