Thread: 97 blower motor wont fit a 99
Results 1 to 7 of 7
  1. #1 97 blower motor wont fit a 99
    GXP Level Member ryangtp89's Avatar
    Maine
    Soo my heater stoped workin in my 99 gtp, soo i take the blower motor out of my 97 gtp and the only thing that doesnt fit is the wiring plug that makes it work, if you know what i mean. Soo i called up carquest to make sure and the women told me that they sell the blower motor for the grand prix through 97-03 yea that makes sence, but where you plug in the wire its setup a little different and it just wont fit in it. Soo im gonna have to end up buying a new one. Its 88 bucks btw at carquest.
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback, 3.4mps, NGK TR55's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny, flipped motor mounts, spring blockers, prj 10.4mm wires, Sloted rotors & Ceramic brake pads,Alternator Voltage Booster. zzp 1.9 rockers & 105# springs
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Im suprised it had a plug on it as I see many of the parts store blower motors with bare wire ends that you use your old connector on
    Maine
    really, wat do you do just take it off of the old one and just put the plug on the new one
    GTP Level Member GTPluv's Avatar
    Enid,Ok
    Mine came with the new plug. No bare wires
    Maine
    good im gonna buy one tomorrow, im pretty sure its the blower motor, it was like easy to take out but it was just a ***** to actully pull it out after getting all the bolts off of it. no biggy. i probably should get my old one tested first before buying one
    Fort Wayne, IN
    I would hook that fan up to a battery and make sure, I dont see them fail too often but the resistors on the other hand are always going bad. Put a volt meter on the fan wires with it plugged in and turn the fan on and go through the range of speeds and see what you get.
    Maine
    Hey i got the new blower motor today and installed it. It blows hot heat!!!!! it works awsome. the instal was just a pain, cause their was little room and my back was flat across the floorboard and i had to muscle through the wires, but other than that it was easy. Thanks for all the help guys
  1. rear window regulator/motor install write up
    By ExpyGator in forum General Tech Discussion
    Last Post: 11-17-2009, 12:52 PM
