Thread: pacesetter headers ?
Results 1 to 20 of 30
  1. #1 pacesetter headers ?
    GXP Level Member ryangtp89's Avatar
    Maine
    my next mod is gonna be the pacesetter header package from zzp. Im just waiting for the cash to get it then i can have someone put it on along with my brand new slp dual cat back exhust sytem still sitting in the box in my room. Well whats ur guys input on that pacestter header package ? This is what i want to go with so is their anything i need to get or watch out for ? I do know that this package comes with crappy paper gaskets and i think theirs a need for longer bolts but im not really sure.
    Also when i get the headers and i am ready to put it all on, well actully im gonna have someone else do it , well when i am ready to put the header package on, which is 450 at zzp and my slp dual cat back exhust should be everything i need and that should finish my exhust work? do i have to do anything else, Doing all this does that mean i dont need to do any deletes or anything ?
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback, 3.4mps, NGK TR55's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny, flipped motor mounts, spring blockers, prj 10.4mm wires, Sloted rotors & Ceramic brake pads,Alternator Voltage Booster. zzp 1.9 rockers & 105# springs
    Bastard Reptile's Avatar
    Kansas City, MO
    Get yourself the good GM metal gaskets...
    The longer bolts you need are where the front header bolts to the crossover.
    Maine
    Should i get the zzp pro kit, if you know what im talking about. where would i get the metal gaskets and do they make them to fit the pacesetter headers ? where do i get the longer bolts at ?
    Kansas City, MO
    Yeah, all they do is give you what...
    Pro-kit includes O2 extension, upgraded flange gasket, O2 bung plug, and matched piping for better sealing.
    they might have most of it covered...but I don't think they do.
    You're going to need better clamps. Get yourself some slip joint clamps, also called step clamps from NAPA. Get a couple long stainless bolts/nut/lockwashers from a hardware store, and you should be good.
    Maine
    ohh ok ill right that down for when the time comes i will get it, and throw it in the box, soo when the guy installs it he wont charge me an arm and a leg for extra work. thanks for the help, i think that covers everything. Once thats done i can move onto my next steps into modding my allmighty gtp lol. Ill get some colder plugs probably autolite 104's and a tstat 180 then ill throw on a 1.0 pcm from zzp and then a 3.4 pulley
    Kansas City, MO
    Quote Originally Posted by ryangtp89 View Post
    Keep your receipt...
    Everyone I know who has purchased one of those things, has sent it back for a refund. I'm even putting an engine in his car now because of what we believe to be caused by the pcm and fuel/timing.
    Far be it from me to bash a vendor (right guys?) But I wouldn't do it. period.
    Now, I'm not sure if DHP is selling PCM's anymore or not, someone can say for sure...I don't see them on the major sites....but they're tried, tested, and proven. I don't know what Zooomer has going on with his programming, but I and a few of my close buds aren't convinced yet that they should even be selling them all....
    ok, off my soapbox
    Maine
    oh btw should i pay the extra 45 bucks for the pro kit, do i really need it ? or just get the stuff you told me to get.
    Kansas City, MO
    Well if you really want to break it down....let's see.
    GM Gaskets...about $4 each maybe?
    Bung Plug....again, only a few bucks from an exhaust shop
    The exhaust clamps are going to run you about $7 each
    Wire to extend the O2 harness....literally...just pennies right there. Cut, splice and ad about 20 inches to the current connector.
    I got me a pipe expander at Harbor Freight....$13 and I did that part myself.
    up to you really.
    Maine
    Dam soo i should defently not wanna get that pcm from zzp, Wat about overkill i think its called. Is their any other pcm's or just dhp. When i do get the pcm do you just put it in or do u have to do other **** than just slip it in ?
    Kansas City, MO
    I've heard good things about Overkill. He does it custom for your mods also.
    Indiana
    XXX Nevermind lol
    Moore, Oklahoma
    Overkill makes damn good PCMs period. He's helped me alot with my car, more than anyone ever has on the Powertuner board. I'd recommend him hands down, its worth the price if you want your car running right.
    As for the install kit, not worth it, do what Reptile says, buy it the **** on your own. He's saving you money.
    I wouldn't call the PCM thing a bash Reptile its the truth. Hell, there rails suck, been there done that. And there customer support can be less that desired, again, been there done that.
    Shawn W. Larsen
    Moore, Oklahoma
    SLPs are alright... if you got the money get the TOGs, trust me on this. Check out 3800performance.com
    Shawn W. Larsen
    Maine
    hmmm ok then, well i got alot of time basically before ill get into that. Im saving my money right now for the pacesetter header package then ill wait till spring to have it installed. Then ill go from their.
    Kansas City, MO
    Like I said....I'm just trying to give my "opinion", and you know what people say about those. I'm sure there are people here that have the ZZP ones....but I just haven't ever seen anything good about them on my experience.....Ultimately it's your money and your decision.
    Maine
    oh no its cool, Id rather get opinions and experiences then to find out the hard way.
    so when you do get the pcm do u just replace it with the old one and is that it, or is their more to it ?
    Jan 1970
    Maquoketa, Iowa
    another option from expanding the pipe, is to make a few notches in the pipe no wider than the band clamp to help it seal better, that way when your tightening the clamp/pipes down they have room to contract
    Maine
    yea i dont really get any of this, soo hopefully the person installing the header and exhust system will know what hes doing
    Topeka, KS
    Overkill has had some pretty good feedback. All you really do for the pcm is unbolt the harness remove the old pcm and repeat backwards. Pretty straight forward. Sometimes you have to do a case learn if it wont start. I used to have a link for his website. Someone Chime In if you know it.
    On expanding the pipe all you really do is stick a little cylinder inside it that expands as you turn it usually with a wrench. Kinda hard to explain if you've never scene it. Most exhaust shops have a hydrolyic version of this.
    Kansas City, MO
    I don't know why....but I love posting this vid.
    Here's my pacesetters after install...open header. LOL
    Open Headers Vid
