Thread: car didnt like to get waxed
Results 1 to 12 of 12
  1. #1 car didnt like to get waxed
    MINNESOTA
    I just got done waxing my car using a porter cable.it took me about 7 hours and after i was done it sat in the garage for a day. now after i went outside and started it,i get this-
    traction control off
    stability control off
    service ABS system
    service traction control
    service stability control
    service variable effort steering
    now the steering is a little harder.i unplugged the ground on the battery and left it for about 3-4 minutes but that didnt help.
    little help please.thank you
  2. #2 Re: car didnt like to get waxed
    Donating Users str3etgl0w's Avatar
    Jun 2011
    Saginaw Mi
    Have you checked all the connectors under the hood and fenders? Maybe one was loose and the vibration did it?
  3. #3 Re: car didnt like to get waxed
    MINNESOTA
    im kind of doing that at this moment.will let you know if i find anythig.thanks
    started the car up and everything back to normal
    just dont get it.
    thanks for the reply
  4. #4 Re: car didnt like to get waxed
    Jun 2011
    Saginaw Mi
    That's goods prob just a loose connection somewhere or your car just straight up didn't like the wax maybe it was warning you lol
  5. #5 Re: car didnt like to get waxed
    Pennsylvania
    This might be a wheel bearing/speed sensor/abs something, or perhaps a fuse loose/going bad or something from what I've seen... but it's kind of infrequent, yes? interestingly, happened right after I use a PC to polish the hell out of a GP. Probably best to just start replacing parts beginning with the cheapest and moving on up.
  6. #6 Re: car didnt like to get waxed
    MO
    hate it when random stuff happens. I changed the oil on my dad's car for him, went to start it and it won't start. Turned out the battery was dead (wtf)
    <brandonl2000> LMAO D!!
  7. #7 Re: car didnt like to get waxed
    SE Level Member SMazza's Avatar
    Jun 2011
    Eastern Pennsylvania
    Maybe you built up enough static electricity to fry the BCM or something?
  8. #8 Re: car didnt like to get waxed
    GT Level Member tcman49's Avatar
    Apr 2011
    Palm Coast, Florida
    Your car was just fuc@in' wit you
  9. #9 Re: car didnt like to get waxed
    Pennsylvania
    Quote Originally Posted by SMazza View Post
    That would be... a lot.
    This much:
  10. #10 Re: car didnt like to get waxed
    MINNESOTA
    Quote Originally Posted by tcman49 View Post
    I havent had any major problems with it,6 years and it still going strong.i was starting to get afraid that it was time for it to start breaking down on me.
    got to love my GP
  11. #11 Re: car didnt like to get waxed
    Pennsylvania
    Well, lemme know if you come up with anything, I'm curious.
  12. #12 Re: car didnt like to get waxed
    Pennsylvania
    Threw a code that only a TechII could see: C0550 - Your Electronic Brake Control Module is being a little b*tch. GM manual says to replace it.
    Edit: Luckily, they're only $800. Wonder if you can get it repaired.
    Edit: $620
  1. I didnt want to play catch
    By nyydmb12 in forum The Rant Forum
    Last Post: 09-10-2010, 02:08 PM
  2. So i went to the track tonight. Didnt do too bad i guess.
    By Boosted98Gtp in forum General Tech Discussion
    Last Post: 06-21-2010, 06:01 PM
  3. 350z didnt want 2 race!!!
    By a98gtp4u in forum Track Sessions and Kills
    Last Post: 11-09-2009, 04:30 PM
  4. Claybar and waxed
    By SlowM90 in forum Visual/Body Modifications
    Last Post: 04-13-2009, 02:41 PM
  5. i didnt see where i could put this problem?
    By NME in forum Off Topic Discussion
    Last Post: 12-29-2007, 02:10 AM
