Thread: 05 GP Air Conditioner Not blowing cold anymore
Results 1 to 10 of 10
  1. #1 05 GP Air Conditioner Not blowing cold anymore
    Michigan
    Hey guys,
    I have an 05 Grand Prix that has just recently stopped blowing cold air when I turn the AC on. I had the car in the shop for some repairs recently and I'm wondering if the mechanic could have done something to mess around with my AC. I've never had a problem with the AC until he got his hands on my car.....never going to happen again....This may all be a big coincidence and if so, is it possible to repair the AC myself ?
    The fan works, just blows warm air instead of cool. I believe I can start with trying to recharge my AC.
    Any suggestions on supplies or if I should start diagnosing another place ?
    Thanks in advance!
  2. #2 Re: 05 GP Air Conditioner Not blowing cold anymore
    does the compressor come on?..if not start there
    SMGPFC Member #10
  3. #3 Re: 05 GP Air Conditioner Not blowing cold anymore
    GT Level Member jmoore4294's Avatar
    Don't recharge it until you come to the undeniable conclusion that it is indeed low on freon.
    2004 Pontiac Grand Prix GT2 -Wizaired-DHP Tune-180° Thermostat-GMPP STB w/brackets F/R-Bilstein HD Struts w/SSC-Projector Retro-Black SPO Grilles and Spoiler-ZZP Volt. Booster & Alt Rewire
  4. #4 Re: 05 GP Air Conditioner Not blowing cold anymore
    MO
    This is gonna sound dumb, but make sure your snowflake is on. I know a girl who, after a year of driving her car, just figured out why her a/c didn't work. She didn't turn the compressor on.
    <brandonl2000> LMAO D!!
  5. #5 Re: 05 GP Air Conditioner Not blowing cold anymore
    GT Level Member RyanL's Avatar
    Montreal, Quebec, Canada
    ok first off dont be doing this stuff yourself if you have no experiance! mechanics need an a/c license for a reason. that **** is extremly poisonous!
    so first open your hood and locate your ac compressor, start the engine and get someone to turn on and off the ac while you look to see if the clutch on the pullie engages. look at the pullie and you should see the middle start spinning when on and not spinning when a/c is off. if it spins then your a/c compressor is usually ok. also when it engages you should see your rpm flutter for just a second.
    if it does spin you have a leak and need to have dye put into the system so they can find out where it is and what needs to be replaced.
  6. #6 Re: 05 GP Air Conditioner Not blowing cold anymore
    also what work was done on your car at the garage? if you think it could have been them
  7. #7 Re: 05 GP Air Conditioner Not blowing cold anymore
    SE Level Member Ophidia's Avatar
    Nov 2010
    West Fargo, ND
    "Contact of 1,1,1,2-tetrafluoroethane with flames or hot surfaces in excess of 250 &#176;C (482 &#176;F) may cause vapor decomposition and the emission of toxic gases including hydrogen fluoride and carbonyl halides.[18] 1,1,1,2-Tetrafluoroethane itself has an LD50 (lethal concentration for 50&#37; of subjects) in rats of 1,500 g/m&#179;, making it relatively non-toxic. However, its gaseous form is denser than air, and will displace air in the lungs. This can result in asphyxiation if excessively inhaled.[19][20] This is what contributes to most deaths by inhalant abuse."
    Only poisonous if you try to kill yourself with it, essentially.
    2004 GT2 Leather, Sunroof, heated seats, other stuff, but only a little DIC. Also, Kawi Vulcan 2000 http://tinyurl.com/ophidia
  8. #8 Re: 05 GP Air Conditioner Not blowing cold anymore
    Quote Originally Posted by Ophidia View Post
    "Contact of 1,1,1,2-tetrafluoroethane with flames or hot surfaces in excess of 250 °C (482 °F) may cause vapor decomposition and the emission of toxic gases including hydrogen fluoride and carbonyl halides.[18] 1,1,1,2-Tetrafluoroethane itself has an LD50 (lethal concentration for 50% of subjects) in rats of 1,500 g/m³, making it relatively non-toxic. However, its gaseous form is denser than air, and will displace air in the lungs. This can result in asphyxiation if excessively inhaled.[19][20] This is what contributes to most deaths by inhalant abuse."
    Ok I didn't understand about 85% of that lol but it the poison symbol on the ac recovery machine at work.
  9. #9 Re: 05 GP Air Conditioner Not blowing cold anymore
    Charles City, IA
    I am ase certified for r12/r134a recovery and recycling, and I will tell ya from experience is best to have a shop pull the system into a vacuum and recharge with leak detector dye. When you do not pull the system into a vacuum you will still have moisture in the system that will not allow it to work properly. At our shop we get about $100 for a recovery and recharge.
    SMGPFC Two Nipple General
  10. #10 Re: 05 GP Air Conditioner Not blowing cold anymore
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    i searched and found this thread. so thats why its being revived lol
    but freon is actually heavier than oxygen so it sits low on the floor. if you ever leaked a huge amount in a room then you would want to make sure you stand up and not get on the floor. outside with a small amount you wouldnt have to worry about it. just dont blast the stuff directly in your face. the biggest thing about it is if you ever got caught its like a 10k fine.
  1. Overheat and blowing cold air
    By skibender in forum General Tech Discussion
    Last Post: 12-22-2010, 08:57 PM
  2. Blowing cold air
    By tracker1925 in forum General Tech Discussion
    Last Post: 12-11-2010, 06:41 AM
  3. Heater blowing cold on drivers side
    By sophie in forum Introductions/Noob Questions
    Last Post: 11-03-2010, 08:00 PM
  4. air conditioner compressor
    By justwhisen in forum Shops and Community Heroes
    Last Post: 09-03-2008, 07:29 AM
