Thread: Car Alarm Installation...
Results 1 to 11 of 11
  1. #1 Car Alarm Installation...
    Apr 2008
    Ok, I bought this car alarm... After skimming through the manual, I see one thing I don't quite understand.
    There are wires for Lock COM, Lock NC, and Lock NO.
    What's up with that? Lol
    If it matters, I'm in a '97 GT.
  2. #2 Re: Car Alarm Installation...
    Oklahoma
    Lock COM - probably the ground wire, or could be the common connection on the relay
    Lock NC - Lock, Normally Closed, probably a connection to the relay for the alarm
    Lock NO - Lock, Normally Opened, same as above, just open
    Normally opened and normally closed refers to the relays state with no power applied to it.
    The common is connected to the NC in its power off state. So whatever is connected to common flows to the NC terminal. When power is applied the relay connects to he NO terminal and what is connected to the common will then flow to and be connected to the NO terminal.
    Hope that helps out.
  3. #3 Re: Car Alarm Installation...
    Apr 2008
    thanks, that cleared up a lot. one more though...
    'Purple wire: TACH wire(AC input) connect to TACH signal wire (coil or injector)'
    Am I correct in assuming this means tachometer? where might I find this wire?
  4. #4 Re: Car Alarm Installation...
    Oklahoma
    That one you are going to have to wait for someone else on as I am not sure. I believe, and dont quote me on this, but I believe that wire would probably come from the crankshaft position sensor, if not there then it would come from the PCM.
  5. #5 Re: Car Alarm Installation...
    Saraland Alabama
    it's the tach wire, and can be found at the coils, check out 12volt.com for a diagram on where everything is located
  6. #6 Re: Car Alarm Installation...
    GTP Level Member s1795so2's Avatar
    alhambra, Il
    I will try to get you some directech sheets on the wires, where they are and what they are by later tonight or tommorow.
    Steven Oliver
    2004 GTP comp-g WS6. Gator and suede all around interior.
    Advanced MECP certified installer, custom upholsterer.
    <img src=http://i86.photobucket.com/albums/k87/s1795so2/random%20pics/manbike.jpg border=0 alt= />
  7. #7 Re: Car Alarm Installation...
    Apr 2008
    Ok, I put this project on hold for a while due to lack of free time...
    Everything works except remote start. Well remote start probably works, but i haven't tried it because I don't want to fry my starter or anything because the system has no way of telling when the car's started.
    I looked at the12volt.com, and they have two pages on the '97 GP.
    This one: 1997 Pontiac Grand Prix Alarm, Remote Starter, Keyless Entry Wiring Information
    And this one: 1997 Pontiac Grand Prix Alarm, Remote Starter, Keyless Entry Wiring Information
    The first one says that the tach is the purple/white wire from the ignition module, but does not say that it is an AC current (the alarm system requires the tach signal to be AC).
    The second one says it's the white wire on the driver's side of the PCM and that it's AC.
    I'd like to use the one from the ignition module, as touching the PCM scares me
    My question is, how would I test AC current in the car with a multimeter? Where would I put the ground side? Can I ground an AC current into the car's DC ground?
    Also, where would I find the ignition module? Do the wires that run from the ignition switch go straight into the ignition module? I'm pretty new to this.
    If I can't use the ignition module wire, I have another dilemma I moved my PCM around while getting rid of my airbox to install my cold air intake. I don't really remember which side of the PCM was on the driver's side before.
  8. #8 Re: Car Alarm Installation...
    Apr 2008
    Chillin at the Beach , VA
    Your ignition control module is under your coil packs. That is what they are bolted to.
  9. #9 Re: Car Alarm Installation...
    Apr 2008
    Sorry to bump such an old post...
    I finished the alarm installation a day or two after my last post on this and thought it might be good to post the solution here for anyone else with the same problem.
    The correct wire is the white one towards the right of the harness on the ignition control module. I'm pretty sure it is the 5th one from the right.
    I got a hold of GM's techline software and looked it up in there before trying. I didn't even have to touch the PCM.
    Also on my alarm (not sure if they are all like this) it won't start unless the parking brake is applied. I just tricked mine into thinking the parking brake is always on.
  10. #10 Re: Car Alarm Installation...
    Saraland Alabama
    Quote Originally Posted by Guitarist575 View Post
    you have one designed for a manual is all
  11. #11 Re: Car Alarm Installation...
    Apr 2008
    Thanks for the update. Glad to hear you got it all worked out.
  1. Tweeter Installation
    By Burgundyman in forum Audio, Security & Visual Electronics
    Last Post: 08-13-2008, 12:37 AM
  2. HELP! Bypass alarm!
    By GreenNirvana101 in forum General Tech Discussion
    Last Post: 05-03-2008, 06:07 PM
  3. Does my GP have a factory alarm?
    By Deezul_AwT in forum General Tech Discussion
    Last Post: 03-23-2008, 10:48 AM
  4. Alarm L.E.D.
    By Toasty in forum Visual/Body Modifications
    Last Post: 03-17-2008, 01:56 PM
  5. Stock Security Alarm
    By 99redgt in forum General Tech Discussion
    Last Post: 02-22-2008, 05:10 PM
