Thread: Video & Picture Diagnosis
Results 1 to 10 of 10
roundbox52 Video & Picture Diagnosis 06-07-2011, 08:43 PM
TheOtherNick Re: Video & Picture... 06-07-2011, 08:45 PM
roundbox52 Re: Video & Picture... 06-08-2011, 05:51 PM
whiney Re: Video & Picture... 06-08-2011, 06:26 PM
FoSHO99 Re: Video & Picture... 06-08-2011, 06:59 PM
roundbox52 Re: Video & Picture... 06-09-2011, 08:33 AM
SJAndrew Re: Video & Picture... 06-09-2011, 09:27 AM
matt5112 Re: Video & Picture... 06-09-2011, 01:34 PM
  1. #1 Video & Picture Diagnosis
    New York
    2001 Grand Prix - no mod's. 114,000 mi....rusted out bottom from WNY winters.
    Check out this link for the video/audio and the attached pictures along with the description below:
    YouTube - ‪MOV006‬‏
    I've been hearing this drone/humming sound from my front end lately, specifically the drivers side front. It originally was pretty faint, but as the weeks went on it got louder and louder. Instead of hearing it only when I was going around 45 mph I now hear it starting at around 20 mph and it gets louder as I go faster.
    When I get to about 45 mph I start to feel a vibration in the gas pedal. If I slightly turn the wheel to the left the vibration goes away, but the sound is still there.
    I was recently doing some brake work and noticed a bunch of grease piled up on a part. Yes a part - I'm not too mechanically savvy on part identification. Anyways, I have attached a few pictures of this grease on this part. I checked the rubber boot but I didn't find any noticeable cracks or breaks in it.
    I am wondering if the vibration and sound I am hearing is related to all the grease I found. Hopefully someone can help!
  2. #2 Re: Video & Picture Diagnosis
    Charles City, IA
    You need an axle and possibly a wheel bearing.
    SMGPFC Two Nipple General
  3. #3 Re: Video & Picture Diagnosis
    New York
    Quote Originally Posted by TheOtherNick View Post
    Anyone else have any ideas or does this seem to be very logical? Can I replace the inner CV Joint rather than the entire axle? How do I know if the wheel bearing needs to be replaced?
  4. #4 Re: Video & Picture Diagnosis
    swift current,sask.
    3rd pic from the bottom, looks like the brake line is fubar'ed. jack the car up and see if the wheel has any play when trying to rock between 12' o clock and 6' o clock. if there is play then you need a new one.
  5. #5 Re: Video & Picture Diagnosis
    Jan 1970
    Maquoketa, Iowa
    That's CV grease. It's just easier to buy a new drivers side axle. A GT/GTP axle will work on the drivers side, passenger side of a GTP needs a GTP axle.
    The brake line looks like it has some grease on it and is a lil rusted, don't think its your problem now but would be a good idea to fix soon.
  6. #6 Re: Video & Picture Diagnosis
    New York
    Quote Originally Posted by FoSHO99 View Post
    I just replaced part of the brake line going to the driver's side rear brake. Had a huge leak in it from the constant salted roads in winter!
    Just this morning the rear passanger's side coil spring broke on me - it was rubbing against the tire! Any chance I can just replace the spring and not the entire strut?
  7. #7 Re: Video & Picture Diagnosis
    Denver
    Quote Originally Posted by roundbox52 View Post
    Yes, of course, get a new spring and a spring compressor.
    But, you'd be CRAZY to go through the hassle of separating the spring from the shock without replacing both.
    Do yourself a favor and replace BOTH rear struts with Monroe quick struts. They're bolt in and have all new parts (new bearing pocket, shock, spring, etc). They're about $120 a piece from rockatuo. Replacing one spring without the other is asking for problems - the new spring will be WAY more stiff than the existing one and mess up all of the suspension geometry (to have one corner 2" higher than the rest).
  8. #8 Re: Video & Picture Diagnosis
    New York
    Quote Originally Posted by SJAndrew View Post
    Okay - I just bought a pair of Monroe Econo-Matic struts - Same company, same quick install concept... Hopefully they work just as good as the more expensive Quick-Struts. Price was $76 after using a $40 coupon code at advance auto. I haven't been able to beat Advance Auto prices anywhere since they have such great coupon codes and have local quick pickup.
  9. #9 Re: Video & Picture Diagnosis
    They use an economy strut.
  1. Diagnosis?
    By bobabooie in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2011, 02:15 PM
  2. 5 things I like in this picture. Can you name them all?
    By GR8racingfool in forum Off Topic Discussion
    Last Post: 07-28-2010, 09:44 AM
  3. SF Bay Area assistance (LIM leak diagnosis)
    By Toxicologist in forum General Tech Discussion
    Last Post: 01-28-2010, 11:15 PM
  4. Funny Picture
    By Billyb in forum Off Topic Discussion
    Last Post: 09-07-2008, 06:18 PM
  5. 1999 automatic transxale diagnosis help
    By Budman in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-16-2008, 08:23 AM
