Thread: NO a/c please help !
Results 1 to 6 of 6
  1. #1 NO a/c please help !
    SE Level Member hcokiid18's Avatar
    May 2011
    Dayton, Ohio
    Ok so I have spent like $75 on trying to recharge my air and I am beyond TICKED off !!! I've used the little cans, big cans, dye cans blah blah.... After putting it in - I had NO cold air not even for a few minutes... I was mad - went home parked my car and could hear a hissing noise coming under the hood/ground area but seen nothing... it hissed for awhile... also I noticed while putting the freon in it looked like smoke under my car but not a lot just alittle but I am guessing it was freon? I don't know.. I can't find a leak if there is one... Also I noticed my compressor isn't spinning... Does it only spin if it holds freon? I am confused...
    04 GTP Comp G. 3.4'' Pulley, Pace setters, 180*STAT, Tuned,Slotted Rotors,Thrasher Intake, 152k
  2. #2 Re: NO a/c please help !
    Denver
    If you're low on refrigerant, your compressor will not engage.
    If you have a hissing noise coming from the underside of you car I wold suspect you've picked up a rock and have a hole in your condensor.
  3. #3 Re: NO a/c please help !
    It sounds like you could have broken/worn AC lines or have a hole in your AC condenser.. I would take it to a good shop that will inspect the ac system.. They have the correct tools to do so...
    Snorlax strikes again.
  4. #4 Re: NO a/c please help !
    Feb 2008
    I just replaced my hoses due to the exact same problem. I had a crack in the little canister that sits right off the compressor. Took me 30 minutes to replace the hose assembly and was about $80 from Auto Zone.
  5. #5 Re: NO a/c please help !
    GTP Level Member
    springfield IL
    a "good" shop is the way to go!!!
  6. #6 Re: NO a/c please help !
    GTP Level Member
    springfield IL
    Quote Originally Posted by DanGTP View Post
    is that called the evap canister??
