Okay so my car was throwing codes for the intake air temperature sensor. I replaced the intake air temperature sensor with a new duralast 1. I'm still getting the same code p0112 and i cant figure out how to test the wire and fix it. Help
Well for power could use a power probe which you just touch the wire and if the light bulb lights up you have power there or you could use a multimeter. with the multimeter you can see how much power is there and you can also test if it is an open or closed circuit when using Ohms. Hope this helped.
At night.
get a spray bottle with tap water.
spray and watch for sparks with no lights on.
