Thread: Battery Float Charger
Results 1 to 13 of 13
  1. #1 Battery Float Charger
    OKC, OK
    A battery float charger is a simple electronic device that connects to your battery post and a 110 volt AC outlet. All it does is to keep the battery at its current level.
    It is mainly for a vehicle that sits for long periods and will have the ECM drain the battery: possibly to the point of not being able to recharge it and having to buy a new battery.
    I currently use a float charger on mione as it will sit for a week to a month at a time. If you drive everyday, then you probably would not need one, but it could keep your battery living longer by no discharging and then recharging overnight.
    Also, for people in frigid climates, it could make a world of difference going from overnight to the morning. NOTE- I always unplug the AC first then disconnect the battery clamps before driving. It is unknown to me if you need to disconnect the battery clamps: I do it for extra protection. They run from $4 on special at Harbor Frieght to ???. Next to an engine block heater, these are a great way to protect your investment.
  2. #2 Re: Battery Float Charger
    Charles City, IA
    Spam?
    SMGPFC Two Nipple General
  3. #3 Re: Battery Float Charger
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    spam...........
  4. #4 Re: Battery Float Charger
  5. #5 Re: Battery Float Charger
    Charles City, IA
    I know thats what has me perplexed?
  6. #6 Re: Battery Float Charger
    Donating Users gtpsleeper's Avatar
    Lawrence, Kansas, United States
    "My car is a racecar like Planet Fitness is a gym...."
    proud mark VIII victim!!! suck it...
  7. #7 Re: Battery Float Charger
    Feb 2008
    Good information either way...
  8. #8 Re: Battery Float Charger
    OKC, OK
    Dan GTP seems to of gotten what the thread was about. The rest of you must still be in high school not to be able to recognize a helpful suggestion. You might ask the administrator to remove your reply as your reply seems to be more on the ignorant side than the intellectual. Please don't rant back on this thread as it just makes it harder for people to utilize it thinking they have to read through it all of the crap.
  9. #9 Re: Battery Float Charger
    you've also got to realize that most of the time when someone is advertising a product on here it is normally a spammer and normally they disappear via me. they are just pointing out the obvious and in all seriousness i would never leave my car hooked up to a trickle charger. if the battery cannot maintain itself (so long as the rest of the charging system is up to par) then you should not need it. if it sits for a while, sure (like my bike).
    however, this post seems like it's copied and pasted straight from an advertisement or an informative post on a general automotive forum. that is the only reason we called you out like that. take it with a grain of salt, it is the internet afterall..
  10. #10 Re: Battery Float Charger
    Dallas, GA 30157
    A "trickle charger" and a "float maintainer (charger)" are two different items.
    The trickle charger will keep charging even once the battery reaches full charge
    and will fry a battery. I found this out the hard way, when I forgot to unplug it once
    and left it on for a week.
    A maintainer will bring a battery to full charge and shut down, but will also restart,
    for lack of a better wording, when it senses the voltage has drained below a certain
    level. They are not for charging of a dead battery, but maintaining the charge of a good battery.
    I don't know if the one from HF works as well as the more expensive ones, but it does
    work.
    (haven't been to the site for a while and thought I'd add my 2 penneys worth).
  11. #11 Re: Battery Float Charger
    all good chargers stop charging once the battery is charged. i know the difference, but most new chargers should do both.
  12. #12 Re: Battery Float Charger
    Nov 2009
    It's some good info but whatever happened to just disconnecting the battery if you aren't going to use you vehicle for an extended period of time?
  13. #13 Re: Battery Float Charger
    Dallas, GA 30157
    On some vehicles when you disconnect the battery, the computer has to relearn,
    making for a bad running car for a couple hundred miles.
  1. GTP VS SRT-8 Charger
    By OrangeL67 in forum Track Sessions and Kills
    Last Post: 10-13-2010, 12:22 PM
  2. 118 miles will i have valve float
    By nascartech in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-19-2010, 09:55 PM
  3. Valve Float and Bounce
    By SyntheticShield in forum General Tech Discussion
    Last Post: 12-19-2008, 04:02 PM
  4. Cha cha cha charger!!
    By blackheart in forum Track Sessions and Kills
    Last Post: 12-18-2008, 10:14 PM
