Thread: 05 GT ABS & Traction Control Service Light w/ strange noises
Results 1 to 3 of 3
  1. #1 05 GT ABS & Traction Control Service Light w/ strange noises
    Donating Users zx7r4u2nv's Avatar
    butler, pa
    ok, here is what i have going on.
    I had a tick tick tick noise when going foward at all speeds (not very loud). When in reverse it becomes a louder squealing noise. This is from front left wheel.
    I pulled the wheel and looked at the brakes and rotors assuming it was either dirt or low pads and the sqealer bar was hitting. (both looked fine)
    I then drove to Indianapolis this past weekend and hit a pot hole. Service abs and Traction control lights came on and stayed on.
    I stoped to get some food and shut the car off. When i restarted, the lights were off. (till i hit another bump) This happaned 2 more times and now the service lights stay on even after shutting car off.
    The noice is still exactly the same. I plan on tearing the brakes, rotors, and other parts of the front left apart this weekend but was hoping for some ideas on what the issue may be.
    The Brakes and rotors are about 8 months old and the wheel bearings are about a year old FYI. Thanks.....
  2. #2 Re: 05 GT ABS & Traction Control Service Light w/ strange noises
    Arizona
    (axel foley)
    '00 GT- nothing special
  3. #3 Re: 05 GT ABS & Traction Control Service Light w/ strange noises
    Pennsylvania
    Um, make sure the fuse didn't wiggle out.
    Or the ABS sensor wire thingy on the wheel.
  1. Service ABS, traction control, variable steering
    By Lionel in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-31-2011, 08:09 PM
  2. service power steering abs system traction control warning
    By ltr450tremor in forum General Tech Discussion
    Last Post: 05-06-2011, 10:14 PM
  3. Reduced Engine Power/Service Traction Control
    By SteveNMe in forum General Tech Discussion
    Last Post: 08-07-2010, 10:36 AM
  4. 04 GTP Service ABS/ TRaction control
    By busagtp in forum General Tech Discussion
    Last Post: 09-07-2009, 12:03 PM
  5. abs and traction control light on...why???
    By jtheripper211 in forum General Tech Discussion
    Last Post: 09-01-2009, 03:29 PM
