Thread: Climate Control Issue, please help!
Results 1 to 5 of 5
  1. #1 Climate Control Issue, please help!
    May 2011
    Lancaster, OH
    Ok, I have a 97 GTP, its dark green, and has a black interior, god it gets so hot in there. I have recharged my A/C, and replaced the fuse for the high speed on the blower. It blows cold, but does not really cool the car. It seems to come out everywhere (the floor, the vents, and the defroster). I have an 8 month old, and I really cant drive it anywhere with her because after five minutes she is sweating really bad. Please help!!! What could it be?
  2. #2 Re: Climate Control Issue, please help!
    SE Level Member 98GTPV8etr's Avatar
    Nov 2010
    Petawawa Ontario Canada
    Check the vaccum lines under the hood going around the engine bay on the passenger side i noticed this issue too and it was a broken line sitting by the alt. i taped mine up atm till i get a good connector seemed to fix
  3. #3 Re: Climate Control Issue, please help!
    May 2011
    Lancaster, OH
    Thanks, will check and see what I come up with, I really hope its that simple! I only had one window that worked too, so I couldnt cruise with windows down, so I just took the window motor and regulator out lol, now I at least get a breeze!
  4. #4 Re: Climate Control Issue, please help!
    Oct 2008
    Calgary, Alberta
    I did the same as above, but mine was also broken in the wiring harness. I ended up replacing the line into the car, sliding a brake tubing line beside the transmission selector line, and cutting a slit in the lower firewall insulation/ rubber boot on the inside. (passangers side footwell, the filler panel will need to be removed via 3 plastic rivets.)
  5. #5 Re: Climate Control Issue, please help!
    May 2011
    Lancaster, OH
    Oh joy!! lol, I hope mine is not that much of a pain!! I should get to it here tomorrow, at least I have an idea of what I am looking for. Thanks.
  1. 2000 GTP Climate Control Issue
    By ubuimme in forum General Tech Discussion
    Last Post: 05-23-2010, 08:04 PM
  2. Dual climate control issue
    By mr_gtp in forum General Tech Discussion
    Last Post: 12-22-2009, 07:14 AM
  3. Climate Control Issue - Help!
    By sb7605 in forum General Tech Discussion
    Last Post: 12-17-2009, 10:50 AM
  4. Swapping Single Climate control to a dual climate control
    By mkuhn20 in forum General Tech Discussion
    Last Post: 02-17-2009, 03:35 PM
  5. climate control
    Last Post: 01-27-2009, 09:10 PM
