Thread: burned junkyard gen 5 blower
Results 1 to 5 of 5
  1. #1 burned junkyard gen 5 blower
    Jul 2012
    Clayton,NC
    Theres an 04 gtp in my local junkyard that had a engine fire. The vac tree on top is melted a little but the case isnt to charred. Blower turns fine.
    What do yall think, is it worth pulling? It will be about $150 for the blower and intake?
    98 gtp- cammed intercooled slowness
  2. #2 Re: burned junkyard gen 5 blower
    Jun 2015
    USA
    If it was me, I'd replace the coupling for sure and the snout seal. Everything else should be metal. $50 for those, bearings, and new oil online. While I had it open with the pulley off, I'd consider replacing bearings anyway. Then you're just the roller bearings short of a rebuild. Might as well do them too if you have a few tools.
  3. #3 Re: burned junkyard gen 5 blower
    Jul 2012
    Clayton,NC
    So yeah i went and pulled It and i guess the car was running while on fire. When i pulled it apart everything looked good except for the tips of the rotors by the throttlebody they were starting to flake off which i didnt think gen 5s did. So i guess they got to hot or something. So i guess ill see if anyone has a rotor pack for sale.
  4. #4 Re: burned junkyard gen 5 blower
    GXP Level Member
    Mar 2015
    Tomball
    Gen V's will flake on the tips as well. Pulled one today and it had a couple small flakes missing.
    Jeff
  5. #5 Re: burned junkyard gen 5 blower
    Jun 2015
    USA
    Running on fire, I'd replace the bearings to be safe in case the grease/oil cooked too much. Maybe not if the seal and coupler look ok. You really going to trust the shaft seal though?
  1. HID Burned out. HELP!
    By Points70 in forum Visual/Body Modifications
    Last Post: 05-10-2012, 11:44 PM
  2. got burned?
    By redynscire in forum The Rant Forum
    Last Post: 07-16-2011, 04:24 PM
  3. Burned CD Format
    By arc in forum Audio, Security & Visual Electronics
    Last Post: 02-19-2010, 01:17 AM
  4. 01 GT Fan Blower Controls Burned Out!?!?
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 02-23-2009, 08:00 AM
  5. Burned on an eBay auction
    By Deezul_AwT in forum The Rant Forum
    Last Post: 02-22-2008, 01:07 PM
