Thread: Top of door gasket?
Results 1 to 12 of 12
  1. #1 Top of door gasket?
    Indiana
    I need some assistance.
    I'm not sure what this is called or I would have searched for it. I tried but failed in words I could think of what it might be called.
    Anywho, as you can see mine is cracked and needs replaced. What is this "gasket" called and I'm assuming the dealer may have it? Also, how would one go about taking it off?
  2. #2 Re: Top of door gasket?
    Charles City, IA
    Its the door weather striping.
    SMGPFC Two Nipple General
  3. #3 Re: Top of door gasket?
    Indiana
    Thank you Nick.
    Excuse the blonde moment...
  4. #4 Re: Top of door gasket?
    Donating Users
    South Deerfield, MA
    It is a dealer only item. Iirc, it was about $60-$70 when I replaced mine. You need to pull the rubber bulb weatherstripping out from underneath it that runs across the top of the window. You will see the screws that hold it in when you pull the weatherstripping back.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  5. #5 Re: Top of door gasket?
    Donating Users
    South Deerfield, MA
    I just looked it up on gmpartsdirect. Look under the door tab, then exterior trim. It is called a reveal molding. $60.73 for the coupe.
  6. #6 Re: Top of door gasket?
    Waukesha, WI
    i belive the mirror needs to pulled away to get at the lower screws, the door panel needs to come off for this
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  7. #7 Re: Top of door gasket?
    Indiana
    Thank you gentlemen.
    We need to replace the window motor and speaker in that door anyways. So what better time to do that. But dang...thats salty
  8. #8 Re: Top of door gasket?
    GT Level Member Vegas~Blown's Avatar
    Aug 2008
    vegas
    if this is for a coupe the part number for the left is 10321353 and right 10321352
  9. #9 Re: Top of door gasket?
    Indiana
    So I looked at gmpartsdirect.com and I do not think thats what I need based on looking at their illistration (to me that picture appears to be the plastic pieces surronding the outside of the window). I need the inside gasket on top of the inside edge that seals against the roof when the door is shut.
    The picture I posted is of the inside of the door.
  10. #10 Re: Top of door gasket?
    Donating Users
    South Deerfield, MA
    It's all one piece. The strip that is hanging loose on your door is part of the reveal molding.
  11. #11 Re: Top of door gasket?
    May 2011
    Illinois
    Quote Originally Posted by Silver GTP View Post
    Hi, I purchased the molding (one peice)... Can you let me know how exactly I replace this molding? I can't seem to get to the screws as they appear to be behind the metal door frame. Thanks much.
  12. #12 Re: Top of door gasket?
    Apr 2012
    KS
    Hello, needing the same piece, quick question...is Item #1 the same as in the picture in the link below?
    gmpartsdirect.com: Alternate GM Catalog
    Thanks in advance.
  1. HELP HELP! 99 grand prix 2 door DOOR HINGE REPLACEMNT
    By blortz in forum General Tech Discussion
    Last Post: 05-31-2011, 08:52 PM
  2. LIM Gasket, Head Gasket, or bad sensor?
    By GTFiske in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 08:40 PM
  3. door locks/BCM/speaker/ door question
    By adamlesandrini in forum Audio, Security & Visual Electronics
    Last Post: 03-17-2009, 05:14 PM
