Thread: HELP... My car has a weird SMELL if floored/boosted??
Page 1 of 3 123 LastLast
Results 1 to 20 of 45
  1. #1 HELP... My car has a weird SMELL if floored/boosted??
    SE Level Member hcokiid18's Avatar
    May 2011
    Dayton, Ohio
    Ok so since i've gotten my GTP ive noticed a smell if I floor the car, or if I get my boost pretty high, like being behind someone on the freeway and they floor there car you can smell something, exhaust etc. IDK.... IS this NORMAL ??? what should I do please help me... Is my car about to blow? it runs SO good.... Thx
    04 GTP Comp G. 3.4'' Pulley, Pace setters, 180*STAT, Tuned,Slotted Rotors,Thrasher Intake, 152k
  2. #2 Re: HELP... My car has a weird SMELL if floored/boosted??
    GT Level Member Remnant King's Avatar
    Nov 2010
    Michigan
    If you think its about to blow then it obviously doesnt mean it's running "SO good"
  3. #3 Re: HELP... My car has a weird SMELL if floored/boosted??
    May 2011
    Dayton, Ohio
    No it runs great......... Just has a weird smell if I floor it.. no idea?
  4. #4 Re: HELP... My car has a weird SMELL if floored/boosted??
    Nov 2010
    Michigan
    I honestly don't know, sorry.
    It could be that you're burning oil? And I am only saying this because it's happened with my friends brother except it was on a Taurus X. Everytime he'd floor the gas pedal, or get on it, and burnt oil smell would soon follow.
  5. #5 Re: HELP... My car has a weird SMELL if floored/boosted??
    May 2011
    Dayton, Ohio
    I dont think its burning oil... Doesnt smell like oil really, its that weird smell you smell if someone infront of you on the freeway (sometimes) floors there car, you can see them GO but smell there car as well...
  6. #6 Re: HELP... My car has a weird SMELL if floored/boosted??
    MA
    Like a rotten egg smell?
    SMGPFC Member #9
  7. #7 Re: HELP... My car has a weird SMELL if floored/boosted??
    May 2011
    Dayton, Ohio
    No not really I have no idea what kinda smell it is.... IM lost on this one and I cant take it to a mechanic and be like FLOOR it then you'll smell it... IDK but ive noticed a weird noise in the rear of my car when shut it off.... Like a whisliting noise around my rear tires im sure its nothing of the same problem but my car runs really good, trans is smooth. So I am worried if something is going to fail soon... No service lights are on.
  8. #8 Re: HELP... My car has a weird SMELL if floored/boosted??
    MA
    Is it more of a gas smell? Like when you ride behind a cat less car?
    This is why we need smello-vision lol
    SMGPFC Member #9
  9. #9 Re: HELP... My car has a weird SMELL if floored/boosted??
    May 2011
    Dayton, Ohio
    ha ha. i would say its more of a gas smell rather then an egg... Not really sure, its one of those smells you cant put a name on... Driving regularly you don't smell a thing.
  10. #10 Re: HELP... My car has a weird SMELL if floored/boosted??
    do you own a temp gauge with a laser pointer??? If you understand what I mean by that.
    Do a few heavy throttle runs and pull over and check the cats temp, maybe its almost clogged and burning REALLY REALLY hot and causing that smell when all the extra air and fuel are being dumped into the motor.
    OR you can do it at night and see after a few runs if the cat is glowing red.
    Thats just an idea of what could be causing it.
  11. #11 Re: HELP... My car has a weird SMELL if floored/boosted??
    GT Level Member RamonGTX's Avatar
    menasha wisconsin
    i noticed that same smell last night when i came into boost which was very like wtf was that....the weird thing is it would do it when coming into low boost but when i would floor it all out it wouldnt be there. its odd ima check the cat and see if thats it
    Polished Gen V, 3.1 mps, intercooled, S1X cam, northstar tb, and Tim King built trans with 3.29s and all the good stuff
  12. #12 Re: HELP... My car has a weird SMELL if floored/boosted??
    May 2011
    Dayton, Ohio
    Ramon let me know... BTW is cat the catylitic converter?
  13. #13 Re: HELP... My car has a weird SMELL if floored/boosted??
    utah
  14. #14 Re: HELP... My car has a weird SMELL if floored/boosted??
    May 2011
    Dayton, Ohio
    ??? What... I am just now starting to get into cars sooo... **** lol
  15. #15 Re: HELP... My car has a weird SMELL if floored/boosted??
    utah
    Lol. Yes. That's the cat
  16. #16 Re: HELP... My car has a weird SMELL if floored/boosted??
    May 2011
    Dayton, Ohio
    bahahaha
  17. #17 Re: HELP... My car has a weird SMELL if floored/boosted??
    meow here kitty kitty
  18. #18 Re: HELP... My car has a weird SMELL if floored/boosted??
    Pennsylvania
    Gas smell: either running very rich or leaky injectors. Check spark plugs.
    Rotten eggs: clogged cat
    Burnt oil: rear valve cover is leaking on to rear exhaust manifold. Could be a fire hazard.
    Sweet smell: Burning coolant, maybe lower intake manifold gasket, coolant elbow, etc. Check spark plugs.
    Check all of your fluids for quality and fullness and pull your three front spark plugs to check them. Heck, show us a picture of them. Also, hold a mirror behind the engine to see if you've got an oil leak from the rear valve cover. Report back.
  19. #19 Re: HELP... My car has a weird SMELL if floored/boosted??
    May 2011
    Dayton, Ohio
    just got home from work. will let the car cool off ( if it does considering its 95 friickin degrees out )
  20. #20 Re: HELP... My car has a weird SMELL if floored/boosted??
    utah
    dont touch your brake rotors!
  1. 98 daytona 500 boosts but flutters when boosted
    By mikedinthecity in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-11-2010, 03:30 AM
  2. Stutters when floored
    By 1000PRIX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2010, 08:17 PM
  3. Car Hesitates When Floored
    By 04GTPeeingOnU in forum General Tech Discussion
    Last Post: 07-14-2009, 07:05 AM
  4. Did they ever make a boosted chevy venture stock ?
    Last Post: 04-19-2009, 01:29 PM
  5. Put a boosted 99 Civic si to shame
    By Bogers99GTP in forum Track Sessions and Kills
    Last Post: 10-18-2008, 12:58 AM
