Thread: my car broke down..
Results 1 to 20 of 21
  1. #1 my car broke down..
    GT Level Member andremike's Avatar
    Nov 2009
    chicago
    First off.... my brakes went out. I need a new brake line to the right rear tire. About $300
    I'm told the oil pan is rusting and very thin.. dealer said they can put their finger through thbe pan..then they will replace the gasket and the oil level sensor... about $900
    I need both lower and upper control arms.. about $600
    Then a tune up.. plugs and ires.. then I want to replace both o2 sensors.. about $600
    Oh well.. it will be like new
  2. #2 Re: my car broke down..
    Omaha, NE
    You can do most of that work yourself for less than 1/5th of that cost...
  3. #3 Re: my car broke down..
    where are you getting those prices from?
    those seem way to high
    SMGPFC Member #10
  4. #4 Re: my car broke down..
    Omaha, NE
    They look like dealer prices, and he said the dealer told him about the oil pan.
  5. #5 Re: my car broke down..
    i dont get how replaceing the oil pan is more then replaceing the control arms
    SMGPFC Member #10
  6. #6 Re: my car broke down..
    Nov 2009
    chicago
    They are dealer prices... I left there and brought it to my trusted mechanic.. I just went to the dealer to get my oil change.. $32.00.. I wanted to bring it to the dealer to have another set of eyes look at the car. You never know what they see
    And would you believe the brakes went out after I pulled in the drive for the oil changed... leaked brake fluid all over thbe floor
  7. #7 Re: my car broke down..
    sounds like dealer sabotage,
    your brakes just happen to go out after getting it back from the shop..umm
    SMGPFC Member #10
  8. #8 Re: my car broke down..
    What are upper control arms?
    I have McPherson struts on my car.
    Don't bother replacing the rear O2 unless its throwing a code.... and you know its the sensor, not the wiring.
  9. #9 Re: my car broke down..
    Nov 2009
    chicago
    Maybe... but I kinda of thought the breaks were acting up. Plus there was a trailof fluid on the floor
    I thought replacing the rearO2 senor was agood thing? Increase gs mileage
  10. #10 Re: my car broke down..
    Donating Users
    South Deerfield, MA
    Rear O2 is only for emissions. Front O2 affects gas mileage.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  11. #11 Re: my car broke down..
    Quote Originally Posted by andremike View Post
    brake tubing and tubing bender 30 to 40 bucks, clean the oil pan and paint it with por, its a band aid but it will make it last longer, lower control arms are 60 a side and takes 3 bolts to remove each side, tune up 60 bucks tops.
    unless you are rich, you need to get to work here and save all that money.
  12. #12 Re: my car broke down..
    silver beat me to the punch...
  13. #13 Re: my car broke down..
    Nov 2009
    chicago
    The rear is by the catalytic converter? Ok ll get the front replaced..
    Any of you guys want to come ove and fix it ?
  14. #14 Re: my car broke down..
    Nov 2009
    chicago
    60 for the arm and that comes with bushings? How would I really know that they need to be replaced? The car seems to handle fine
  15. #15 Re: my car broke down..
    Nov 2009
    chicago
    I guess it was both lower control arms..
  16. #16 Re: my car broke down..
    your going to have to get under the front end and look to see if the bushings are cracked mushed up or pieces are missing, then you take a large screw driver or pry bar and try to move the arms, see if the bushing have any play in them, and listen for knocking around while driving when you hit rough pavement.
    dealers suck and like to replace stuff just because sometimes, so you may not need new lca's at all, but you wont know till you look at them.
  17. #17 Re: my car broke down..
    Nov 2009
    chicago
    I do hear a ping when I go up a bump real hard. Anyone have any how to on replacing the control arms and bushings
  18. #18 Re: my car broke down..
    You could buy all those parts, pay for the tow from Chicago to CT and have me do the work for less than they are telling you.
    Seek a second or third opinion.
  19. #19 Re: my car broke down..
    Nov 2009
    chicago
    Ok.. finally got my estimate from my mechanic
    Oilpan,gasket and level sensor. $500.00
    Replace both brake lines to rear of car. $275
    Plugs and wire $215
    Front o2 sensor $136
    Ill wait on the control arms...
    Should I do anything else?
  20. #20 Re: my car broke down..
    Pennsylvania
    At the very least, do the plugs and wires yourself. You'll save $175 and it's super easy.
  1. broke again
    By 94grandprix in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-23-2011, 01:11 PM
  2. so... I think I broke it...
    By Explicit_Spade in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2011, 01:35 PM
  3. I broke it!!!!! :-(
    By klj5022 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2011, 09:01 PM
  4. What Broke?
    By 1quikgp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-16-2010, 07:47 PM
  5. Think I broke something...
    By BwolfGT in forum Off Topic Discussion
    Last Post: 11-12-2009, 08:01 PM
