Thread: halo projector headlight problem
Results 1 to 7 of 7
  1. #1 halo projector headlight problem
    Apr 2011
    indiana
    I have a set of the halo projector headlights for a 97 grand prix and on the drivers side my projection light/regular headlight isn't working. The brights and parking light and turn signal all work just not the "regular headlight". Would changing the bulb help this? Or could the projector be broke?
  2. #2 Re: halo projector headlight problem
    Helena, MT
    seeing as the projector is just a fancy reflector and lens if i'm not mistaken, it's most likely the bulb. probably an h1 bulb, but you'll have to double check.
  3. #3 Re: halo projector headlight problem
    Apr 2011
    indiana
    will do first thing in the morning :-) thank you!
  4. #4 Re: halo projector headlight problem
    GT Level Member Panzer4's Avatar
    Dec 2008
    Dubai, UAE/Camarillo, CA/New Delhi, India
    Agreed that its most likely the bulbs. Afaik they go for 12$ a pair on eBay so you can't really expect them to last too long. Also the wiring harness adaptor they come with is dodgy as all hell, so you might want to check the wiring out of it. Good luck
    "Cry Havoc! And Let Slip the Dogs of War!"
    Black 2000 GTP: 3.4" Pulley, Resonator/U-bend delete, 180 T-stat, Tuned PCM, Thrasher Intake, Larger Radiator, 17" Konig Tantrum Wheels, Red Air Dams. Coming Soon...Projectors, Lighting Mods, Transmission Cooler, Black Rims, Tinted Tails and hopefully Headers
  5. #5 Re: halo projector headlight problem
    Apr 2011
    indiana
    yeah i've noticed that. another question though. is the H1 bulb inside the projection area or is it the same bulb for my regular headlights and my brights?
  6. #6 Re: halo projector headlight problem
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by bcantrell View Post
    Projector is the H1.
  7. #7 Re: halo projector headlight problem
    Apr 2011
    indiana
    thank you :-)
  1. Halo Projector Headlights + LEDs
    By 2000superGrandPrix in forum Visual/Body Modifications
    Last Post: 04-04-2011, 05:06 PM
  2. Projector Halo lights
    By apierce1289 in forum Audio, Security & Visual Electronics
    Last Post: 03-18-2011, 01:30 AM
  3. New halo projector headamps with HID's.
    By Bedwards in forum Visual/Body Modifications
    Last Post: 12-13-2009, 03:59 PM
  4. Halo projector lights
    By Kingkee7 in forum General Tech Discussion
    Last Post: 12-02-2009, 07:48 PM
