Thread: AC Compressor O Rings Picture
Results 1 to 4 of 4
  1. #1 AC Compressor O Rings Picture
    GT Level Member mainecrab's Avatar
    Feb 2008
    Anyone have a picture of know which O Rings to use on the back of the AC Compressor? I tried to use the same type that came off the old compressor but apparently I am leaking freon from the O rings there. I took the ones that looked like the ones that were there before but it leaked, I tried another pair but it still looks like it is leaking slower.
    I bought a bag like this here:
    Item # MT2540, Rapid Seal Kit Application Guide on FMSI
    I see another one here which is just one:
    1997-2005 Pontiac Grand Prix A/C O-Ring and Gasket Seal Kit - 4-Seasons 26728
    Which one is the right one? It does not seem to fit flush right now. Thanks in advance.
    Regards,
    JMorton
  2. #2 Re: AC Compressor O Rings Picture
    GT Level Member sic6's Avatar
    san marcos, tx
    The first link looks right. Are you using the washers or the o-rings. If your using the o-rings then that's your problem, you need to use the washers. FYI any gm sealing washer can be used as long as they are the correct size.
  3. #3 Re: AC Compressor O Rings Picture
    Feb 2008
    I found a chart here:
    http://www.4s.com/Upload/Four%20Seas...%20SEASONS.PDF
    Yeah I used the washer but it looks like its still leaking so want to be sure I am using the correct washer.
    I also read that some of the GM vehicles may need more freon then 1.88LB sticker but not sure mine is affected. It does not seem as cold today as it was yesterday when I pulled a vaccum and refilled.
    I hope I just used the wrong O-Ring. I wonder if I torqued it too much as well that page says about 25lbs
  4. #4 Re: AC Compressor O Rings Picture
    Feb 2008
    So the hose I have on my car is here:
    FOUR SEASONS A/C Hoses,56180 - BestValueAutoParts.com
    Trying to find which washer from here to use:
    I guess I should measure like it says and use the correct washers. I really am not sure why I am having issues with the washer.
  1. Fuel Lines O rings
    By BDEGhost in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-05-2010, 08:45 PM
  2. Injector 0-Rings
    By trailshredder in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-28-2010, 08:55 AM
  3. Hubcentric rings? used for wat?
    By keredwtf in forum Tires & Wheels
    Last Post: 07-14-2009, 02:57 PM
  4. Centering Rings on my new 18's
    By cboth686 in forum Tires & Wheels
    Last Post: 05-09-2009, 12:59 AM
  5. Wheel spacers/hub rings?
    By Iron Indian in forum Tires & Wheels
    Last Post: 04-08-2009, 09:53 PM
