Thread: major mpg imrovement!!
Page 3 of 3 FirstFirst 123
Results 41 to 60 of 60
  1. #41 Re: major mpg imrovement!!
    alright here we go---
    Scavenging:
    -exhaust gases released into the header pipe create a pressure wave
    -as this pressure wave travels down the length of the header primary tube, it is generating a suction wave inthe pipe leaving a low pressure area in the combustion chamber
    -as the pressure/suction wave exits the primary tube, a reflective pressure wave begins traveling back up the primary tube and can enter the combustion chamber as reversion
    ok so your right scavenging and backpressure are not the same but reversion is the same thing as backpressure
    SMGPFC Member #10
  2. #42 Re: major mpg imrovement!!
    Waukesha, WI
    awww **** son, your badazz now
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  3. #43 Re: major mpg imrovement!!
    Banned
    Apr 2011
    wv
    i was pretty sure he was being sarcastic.
    and decrease in weight is gonna be exponential. not direct multiplying. 20lbs out of your car isnt gonna be twice the difference between stock weight as 10lbs.
    just like 200lbs isnt gonna be twice the difference as 100lbs.
  4. #44 Re: major mpg imrovement!!
  5. #45 Re: major mpg imrovement!!
    SWPA
    Scavenging:
    Reversion and backpressure are not the same either.
  6. #46 Re: major mpg imrovement!!
    GT Level Member stevenk8's Avatar
    Macomb MI
    I get about 15-17 city driving and 30-31 on the highway doing 85 all the way up north.
    2002 grand prix gt (CAI,180*tstat,MSD wires,magnaflow high flow cat,ubend delete,18in wheels,HID headlights and fog lights)
    More mods soon to come!
  7. #47 Re: major mpg imrovement!!
    and there not how?
    they both mean the same thing
    SMGPFC Member #10
  8. #48 Re: major mpg imrovement!!
    Banned
    Apr 2011
    wv
    redline, what your saying is that if i remove 1,000lbs of weight out of my car its only gonna be 1 second faster in the quarter, and if it was weightless it would still be in the 11's
  9. #49 Re: major mpg imrovement!!
    Grand Rapids, MI
    ...just close the thread? ugh
  10. #50 Re: major mpg imrovement!!
    SWPA
    and there not how?
    No they don't. Why don't you actually google the term exhaust reversion and you will see how they are not one in the same.
    Exhaust reversion is what makes big cam cars sound so lumpy at idle. It is essentially sucking air back in thru the exhaust. That is not the same as back pressure.
  11. #51 Re: major mpg imrovement!!
    Waukesha, WI
    yea
    RayRay
    92 Turbo miata
    02 lexus is300
  12. #52 Re: major mpg imrovement!!
    ok here we go again
    Reversion:
    -inefficient exhaust systems allow exhaust gasses to be bottled up in the cylinder.
    -the amount of air/fuel intake charge that can enter the cylinder is reduced.
    -higher cylinder pressures from incomplete exhaust blowdown can force burnt gases into the inlet tract during intake valve opening.
    -"mean exhaust flow velocity" is then decreased, reducing maximum engine volumetric efficiency
    that seems to be what back pressure is
    SMGPFC Member #10
  13. #53 Re: major mpg imrovement!!
    if its not the same then they sure the same concept
    SMGPFC Member #10
  14. #54 Re: major mpg imrovement!!
    SWPA
    ok here we go again
    Reversion:
    No, its not.
  15. #55 Re: major mpg imrovement!!
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    Quote Originally Posted by twol8uluz View Post
    Ok, so this was probably due to my own lack of knowledge, but when I first got this car a few months ago I installed a general (cheap) ebay cai. Since I've had the car I've been getting 16-18mpg at best. I thought there was something wrong with that and that I should be getting more. So today for sh*ts and giggles I decided to un hook my battery so it could "reset" itself. Holy sh*t!! Im now getting 24mpg on the freeway doin about 80mph! Guess I should've known about that from the beginning.
    Plus my intake used to make a crazy sucking sound at idle, no more sound either. Maybe this is just common knowledge and I didn't get the memo, but hopefully others will read this and improve their mpgs as well!? .......ooooor am I just crazy and im imagining this? Lol
    If this is true I didnt get the memo either cause I got that sucking sound but hmm Im'a go un hook my battery
  16. #56 Re: major mpg imrovement!!
    Donating Users lflylow's Avatar
    Yakima, WA
    is to
    is not
    is to
    is not
    is to
    is not
    Other then the fact Dpzelenak is actually trying to explain his argument that's what this thread reads like.
    2000 GTP, retro's, Debadged, 15% Tint, SD headers, TB HAI, EGR delete,
    Tuned By Reptile, WBS Perf. LCA's, GMPP rear sway bar Dorman front, Tinted tails.
  17. #57 Re: major mpg imrovement!!
    thanks you- i think?
    SMGPFC Member #10
  18. #58 Re: major mpg imrovement!!
    Banned
    Apr 2011
    wv
    Iflylow ftw
  19. #59 Re: major mpg imrovement!!
    michigan
    Ok, wow! Wasn't looking for an answer on how to totally destroy a thread. I just noticed a dif in my mpg's as far as my dic was reading out. Ok, im wrong, im a noobie...what do u expect? Lol. Thanx for answering my questions and correcting me......I think?? I don't care about the resonator, im not chopping it off. If u want to and thinks it helps, go for it. Im not knowledgeable enough to argue with all of you.
  20. #60 Re: major mpg imrovement!!
    Mullet Member Wotgtp's Avatar
    Connecticut
    Five star thread. Would read again.
  1. Major oil leak!
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-14-2010, 11:47 AM
  2. New to GTP and have major problem
    By phantom2 in forum Introductions/Noob Questions
    Last Post: 09-23-2010, 11:02 PM
  3. Major Problems - Need help, please
    By dellfire in forum Off Topic Discussion
    Last Post: 11-04-2009, 09:37 PM
  4. Will I get major knock?
    By SlowM90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2009, 03:13 PM
  5. major own-age!
    By gtpinsc in forum Off Topic Discussion
    Last Post: 10-31-2008, 10:38 PM
