Thread: power steering fluid
Results 1 to 3 of 3
  1. #1 power steering fluid
    SE Level Member tstaller2005's Avatar
    minneapolis
    Hey guys how do I change the power steering fluid in my 98 GTP. I stupidly and unknowingly over filled the tank after finding out I had a leak in it. I wanna drain the fluid and add new fluid with a stop leak in it to see if I can stop the leak. Can someone tell me how to do this. Thanks
  2. #2 Re: power steering fluid
    Messy way. unhook the return hose which is not pressurized and leak fluid all over the subframe etc.
    Easy way. Pull some out with a turkey baster (Why does that look incorrectly spelled?) and a tube.
  3. #3 Re: power steering fluid
    Banned
    Apr 2011
    wv
    dont use lucas power steering stopleak/rack and pinion repair. the added fluid weight will tear up your PS pump.
  1. Power Steering Fluid
    By Vlad0691 in forum General Tech Discussion
    Last Post: 11-12-2010, 08:48 PM
  2. Power Steering Fluid
    By FriboRage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-22-2010, 01:26 AM
  3. What power steering fluid is best?
    By dl1027 in forum General Tech Discussion
    Last Post: 05-09-2010, 07:55 PM
  4. Power Steering fluid leak--Where?
    By jokyfo in forum General Tech Discussion
    Last Post: 10-06-2008, 05:17 AM
  5. Power Steering fluid leak
    Last Post: 09-28-2008, 11:24 PM
