Thread: Mechanical Oil Pressure Gauge install
Results 1 to 9 of 9
  1. #1 Mechanical Oil Pressure Gauge install
    Apr 2011
    Windsor, Ontario, Canada
    Hey guys, I got a GM oil pressure gauge that I need a hand installing. Ive already mounted the gauge and wired it so that it lites up, I've also already ran the tubing through the firewall from the small hole from the throttle cable. My question is how do I connect my 1/8" tubing? The gauge came with a few fittings which I've already used but no T connector. I'm guessing it needs to go to the sending unit by the oil filter? Is there anyway to do this without having oil run through the car? Does it need to be T'd off? What size T? Anyone got pictures?
    Thanks, Frank
  2. #2 Re: Mechanical Oil Pressure Gauge install
    MA
    mechanical means you will have to have oil running through the car. electric would be different. nice gauge btw ****s sexxy.
    SMGPFC Member #9
  3. #3 Re: Mechanical Oil Pressure Gauge install
    GTP Level Member sdavis11b's Avatar
    Atlanta, GA
    Is it possible to hook up a mechanical gauge in a GP? They ARE alot cheaper than the elec.
    2004 GTP - TEP TRANS, INTERCOOLER, 3.0, AND PLENTY OF KR...
  4. #4 Re: Mechanical Oil Pressure Gauge install
    MA
    Quote Originally Posted by sdavis11b View Post
    i havent done it so i cant say for sure, but yes i dont see why not.. but myself, i payed the extra $ to keep oil out of my cockpit.
    SMGPFC Member #9
  5. #5 Re: Mechanical Oil Pressure Gauge install
    HUDSON
    Use the mech. gauge, just dont use the plastice tubing, use copper tubing of the same size, it can be found at the auto part stores, or hardware stores.
  6. #6 Re: Mechanical Oil Pressure Gauge install
    its quite easy to install, remove the stock sensor by the oil filter, have a little bucket under it, oil will pour out for a bit, and screw in the the new line and brass nut, route the tube so its clear of anything hot, and use Teflon tape on every connection, even on the gauge connection.
    if you want the stock sensor to be installed as well, just put a T in the hole where the sensor was put the tube in the bottom of the T and the stock sensor in the other open end, didn't your new gauge come with instructions? mine did.
    oh and if you jack the car up on the pass side and remove the front wheel you can just reach in there to remove the stock sensor, and install the new stuff.
  7. #7 Re: Mechanical Oil Pressure Gauge install
    why would you not want an electric one? seems like a good way to get oil inside the car.
  8. #8 Re: Mechanical Oil Pressure Gauge install
    Portland Oregon
    If you race it won't pass tech, you can't have oil go past the firewall.
  9. #9 Re: Mechanical Oil Pressure Gauge install
    Banned
    Apr 2011
    wv
    ive been meaning to get around to doing this myself. i have a nice panel i built to hold gauges that goes in place of my DIC.
  1. Volt and oil pressure gauge help
    By DBGP in forum General Tech Discussion
    Last Post: 01-10-2011, 08:38 AM
  2. how to install a oil pressure sender
    By Will5600 in forum General Tech Discussion
    Last Post: 04-08-2010, 07:01 AM
  3. Oil Pressure Gauge...
    By mickey t in forum General Tech Discussion
    Last Post: 08-31-2009, 10:56 PM
  4. fuel pressure gauge
    By gtchris in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2009, 02:43 PM
