Thread: Bosch ABS Schematic wiring AnyOne
Results 1 to 5 of 5
  1. #1 Bosch ABS Schematic wiring AnyOne
    Apr 2011
    south lyon
    98 Grand Prix GT , good Engine Transmission wiring and underbody now showing age.
    I have a Bosch ABS Unit with a ABS warning light on all the time, I have had a look at the ABS.php diagrams (on this site), but they seem to indicate a separate braking motor.
    Has anyone got a schematic on the Bosch unit, especially the multi-way connector and the description of the pins. Thanks in advance Philip
  2. #2 Re: Bosch ABS Schematic wiring AnyOne
    i can try and see if i can find one tomaro
    SMGPFC Member #10
  3. #3 Re: Bosch ABS Schematic wiring AnyOne
    abs light could be as simple as a wheel hub gone bad, did you have the car scanned at a shop to lead you towards the abs unit its self?
  4. #4 Re: Bosch ABS Schematic wiring AnyOne
    wrong section.
    diagrams available on GPONA.com after you register and then go into the GM service manual.
  5. #5 Re: Bosch ABS Schematic wiring AnyOne
    Apr 2011
    south lyon
    Thanks, looks like the site you recommended has all the info i need. Philip
  1. Shift lock solenoid wiring diagram/schematic
    By 40th GP in forum General Tech Discussion
    Last Post: 04-21-2011, 12:27 PM
  2. wiring schematic needed
    By copperpacecar in forum General Tech Discussion
    Last Post: 02-14-2011, 04:18 PM
  3. wiring schematic for 3rd brake light
    By fst in forum Audio, Security & Visual Electronics
    Last Post: 10-28-2009, 04:24 PM
  4. Headlight Wiring Schematic?
    By singularity in forum General Tech Discussion
    Last Post: 09-04-2009, 01:36 PM
  5. Replies: 2
    Last Post: 07-31-2009, 11:37 PM
