Thread: Supercharger
Results 1 to 12 of 12
  1. #1 Supercharger
    May 2011
    Chicago, IL
    anyone have any issues with lean code and misfire due to bad supercharger gasket?
  2. #2 Re: Supercharger
    Yeah, that means you didn't get it sealed right.
  3. #3 Re: Supercharger
    never had issues with new felpro s/c gaskets.
    Did you use garleaks?
  4. #4 Re: Supercharger
    May 2011
    Chicago, IL
    ive never had it off before lol
  5. #5 Re: Supercharger
    Bank one lean means you have a vacuum leak.
    If you used a Garlock gasket...that's the issue.
    Where did you buy the gasket from?
  6. #6 Re: Supercharger
    Quote Originally Posted by RedGtp99 View Post
    Read blue, read.
    I'd suggest checking the rubber connectors on all of your vacuum lines.
    they tend to dry rot after this many years.
  7. #7 Re: Supercharger
    He said bad S/C gasket so I assumed he had it removed.
    I don't read.
    Ever.
    Duh.
  8. #8 Re: Supercharger
    Charles City, IA
    Spray the engine down with Carb clean to find the leak
    SMGPFC Two Nipple General
  9. #9 Re: Supercharger
    Waukesha, WI
    psh..who reads
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  10. #10 Re: Supercharger
    ^^Already stated I don't...thrice.
    Like Matt said these cars are notorius for dry rotting vacuum lines...check them from the Boost Bypass Valve all the way around the Fuel Rail, to the Lower Intake under the Supercharger snout to the bottom of the MAP sensor on the back of the Supercharger...most of the time thats the issue. There is also another set that runs from the Throttle Body to the EVAP canister on the back of the Alternator bracket as well.
  11. #11 Re: Supercharger
    May 2011
    Chicago, IL
    Ive already replaced all the vaccum lines that needed to be replaced. I sprayed carb cleaner underneath the snout and got results. I bought a gasket from the dealership yesterday morning but i have yet to put in on. and no the vaccum lines underneath the snout are fine lol. Another question is the MAF sensor. Ive been hearing a ticking noise when i open the hood and the car is running. i put a stethescope to it and its making a ticking growling noise. Im not for sure but is that suppose to be doing that?
  12. #12 Re: Supercharger
    If the supercharger has never been off, the LIM gaskets have probably never been replaced.
    If thats true.... you're probably eating coolant.
    which means its probably getting into the oil and causing the lifters to get louder.
  1. Supercharger coupling OR Supercharger belt tensioner?
    By 99gtxws6 in forum General Tech Discussion
    Last Post: 07-23-2010, 11:56 AM
  2. Will a 2001 Bonneville supercharger work on a 97 gtp?supercharger swap
    By Bunique7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-10-2010, 08:39 PM
  3. L26 TB on GEN III M90 supercharger
    By Storm in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2010, 07:16 PM
  4. supercharger
    By sUpErClEaNbLaCkMaChInE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2009, 01:50 PM
