Thread: 2000 gtp , supercharger question
Results 1 to 5 of 5
  1. #1 2000 gtp , supercharger question
    Apr 2011
    colorado
    Hi, am having trouble finding where the vaccuum line enters the pass compartment , and the supercharger seems to have a little play in the pulley when removed the belt, it is not up and down play , but similar to the play in a rear end yoke , is this a problem? the oil looks o.k. in the supercharger.
  2. #2 Re: 2000 gtp , supercharger question
    Charles City, IA
    the Hvac line runs in to the passenger compartment in the passenger floor board.
    Sounds like you need a new coupler in the supercharger.
    SMGPFC Two Nipple General
  3. #3 Re: 2000 gtp , supercharger question
    Apr 2011
    colorado
    It was quiet when running, will it break? or is it a must to replace coupler?
  4. #4 Re: 2000 gtp , supercharger question
    there should be no play in sc pulley shaft, snap it back and fourth and you will feel it click when you stop turning it, if its bad. when they are worn out at idle it will sound like rocks in your engine.
    i dont think it can break off, but for a 40 dollar fix why let it go if its bad.
    and after i did my coupler the engine defiantly felt snapper.
  5. #5 Re: 2000 gtp , supercharger question
    I live here. TLSheff's Avatar
    Here is a write up of how to do it How to replace an M90 snout coupler without removing the entire blower
    ZZP is where you get the better coupler and fluids. 2 bottles of GM fluid or 1 of the ZZP fluid for replacing the coupler
    ZZ Performance
  1. supercharger question
    By Lougp05 in forum General Tech Discussion
    Last Post: 01-08-2011, 12:21 AM
  2. Supercharger question on 2000 GTP
    By Pacer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-31-2010, 08:00 PM
  3. Supercharger Question
    By supercharged06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-08-2010, 11:48 AM
  4. Gen 3 Supercharger Question?????
    By gtpracer0186 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2009, 10:02 PM
