Thread: Random plug?
Results 1 to 13 of 13
  1. #1 Random plug?
    GT Level Member ljmonnin12's Avatar
    Nov 2010
    Sidney, OH
    So while I was working on my car today I found this random plug below the hood release and I have no clue what it could go to.. Any ideas?
    -ljmonnin12
  2. #2 Re: Random plug?
    SexyStudmuffin copperpacecar's Avatar
    Feb 2010
    somewhere cold
    maybe temp sensor for the hvac controls
  3. #3 Re: Random plug?
    Pennsylvania
    I'd pop out the headlights and see what you can see - they ought to let you get a good angle on your wiring in there.
  4. #4 Re: Random plug?
    Banned
    Sioux Falls, SD
    Could be to you airbag module
  5. #5 Re: Random plug?
    Quote Originally Posted by miker56 View Post
    All of the GP's were standard for that and it would be connected.
  6. #6 Re: Random plug?
    Banned
    Sioux Falls, SD
    Yea but if his car was ever in a accident and when they repaired it never replaced it
  7. #7 Re: Random plug?
    Reynosa,Mexico
    I believe it's for the temp sensor my GP has it right under the hood latch also.
  8. #8 Re: Random plug?
    Quote Originally Posted by Corona99GT View Post
    I'm going with this one.
  9. #9 Re: Random plug?
    Nov 2010
    Sidney, OH
    would the temp sensor only be necessary for the dual climate control?
    -ljmonnin12
  10. #10 Re: Random plug?
    GT Level Member RegalGS98s's Avatar
    NJ
    Quote Originally Posted by ljmonnin12 View Post
    Should be on any car that has an external temperature reading. I know my Regal has it with the Dual Climate control that shows the outside temperature. If you have a mirror that's supposed to show the external temperature it would have it also. My GTP doesn't show the external temperature so I'll check when I get home if it has the sensor or plug. Might be like the HUD units where they put all the wiring in most cars even though there's no unit. Does the plug look weathered, connector corroded, or does it look like it was connected to something until recently?
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  11. #11 Re: Random plug?
    Quote Originally Posted by MidnightBlue View Post
    The airbag light would be on in that case. OP doesn't mention a light.
  12. #12 Re: Random plug?
    NJ
    I was thinking the same, there would be a light. But finally checked my GTP and the same plug is not plugged into anything and the connectors are corroded. The temp sensor on the Regal is located at the front right on a piece between the AC Condenser and the bumper. It has the same style connector and the same color wires so I think you're good.
  13. #13 Re: Random plug?
    Nov 2010
    Sidney, OH
    Ok. Yeah. When I bought my digital dic I took the old one out and cut all the wires to it. Thinking I had to strip and connect them to the dic but fortunately, the plug in for the dic was just hanging down behind my radio... Makes sense that this would be another random unused plug.
    -ljmonnin12
  1. Random Stalling
    By 02Grandgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-25-2010, 01:17 AM
  2. Just some random fun...
    By SeanGTP in forum Track Sessions and Kills
    Last Post: 09-08-2009, 06:24 PM
  3. random car vs car question
    Last Post: 05-17-2009, 05:48 PM
  4. Random HUD
    By cmw1876 in forum General Tech Discussion
    Last Post: 03-19-2009, 09:35 PM
