Thread: High idle in park and neutral?
Results 1 to 9 of 9
  1. #1 High idle in park and neutral?
    Apr 2011
    Loves Park
    I just installed my zzp PCM on my 2002 gtp and the first time starting the car after the instalation of the new pcm, it began to idle high in park and in neutral. Could the PCM be flashed wrong? I couldn't find any vacume leaks and I have no idea what the problem could be.
  2. #2 Re: High idle in park and neutral?
    How high are we talking?
    Does it ever drop once the car is warmed up?
  3. #3 Re: High idle in park and neutral?
    Apr 2011
    Loves Park
    It will idle up to 2000-2500 rpms without dropping until it's put in gear at which it idles around 1300-1500 which still seems a bit high.
  4. #4 Re: High idle in park and neutral?
    yea something is wrong.
    if you put your stock pcm back in does it still does it?
    the idle should be 1000 at start up then go down to 800ish
  5. #5 Re: High idle in park and neutral?
    Apr 2011
    Loves Park
    I have been sick and haven't gotten the chance to swap them out again. I plan on doing this later tonight tho. Also i have a 3.4" pulley I'm putting on as soon as I fix this problem. I currently have a k and n cai, zzp 3" down pipe with u bend delete and high flow cat, a 180* thermostat. I want to get colder plugs as well but stay with iridium what would you recommend? Will these mods be enough to keep away kr?
  6. #6 Re: High idle in park and neutral?
    http://www.grandprixforums.net/safel...car-17482.html
    read that /\ /\
    get some autolite 605 copper cores for plugs
    and i would not put the 3.4 on with those mods.
  7. #7 Re: High idle in park and neutral?
    Yeah as ffdp said your mods might be able to support a 3.5 but not a 3.4.
  8. #8 Re: High idle in park and neutral?
    Apr 2011
    Loves Park
    What mods other than the zzp PCM, cai, 3" down pipe, u bend delete, high flow cat, 180* thermostat and colder plugs, is required for a 3.4" pulley?
  9. #9 Re: High idle in park and neutral?
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by Injectiongtp View Post
    What mods other than the zzp PCM, cai, 3" down pipe, u bend delete, high flow cat, and colder plugs, is required for a 3.4" pulley?
    Find a local tuner, post up your full location.
  1. Rough idle except for neutral
    By carczar in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-19-2010, 07:33 PM
  2. Replies: 7
    Last Post: 07-07-2010, 08:58 AM
  3. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
  4. 2006 Grand Prix tranny noise in park & neutral
    By stevencharles32 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-16-2009, 12:52 PM
  5. 01 GTP. Car shakes when in Neutral and Park.
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2008, 03:00 AM
