Thread: I think my AC drain is plugged ?
Results 1 to 4 of 4
  1. #1 I think my AC drain is plugged ?
    May 2008
    Florida
    It sounds like a small washing machine in the passenger compartment.
    There is a rubber hose that if I pull out, dumps out water. Should I take an air hose and try to blow this out to clear it?
  2. #2 Re: I think my AC drain is plugged ?
    Waukesha, WI
    run your hand down the firewall on the pas side pull the rubber elbow out and slit the end.
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  3. #3 Re: I think my AC drain is plugged ?
    May 2008
    Florida
    Quote Originally Posted by redlinepontiac View Post
    That in the engine compartment side? Just wanted to clarify....
    Edit:
    This looks helpful
    http://www.paulstravelpictures.com/G...ide/index.html
  4. #4 Re: I think my AC drain is plugged ?
    Waukesha, WI
    yes in the engine compartment its behind the alternator ish. i had a rock stuck in mine
    RayRay
    92 Turbo miata
    02 lexus is300
  1. got a plugged cooling system? fix it the quick (and easy-to-understand) way!
    By Spazztic2003 in forum How To Write-Ups/Tech Tips
    Last Post: 11-27-2011, 12:58 PM
  2. transmission drain
    By mhartwig in forum General Tech Discussion
    Last Post: 11-22-2010, 07:40 PM
  3. radiator drain o-ring size? FAILED motormite drain.
    By alacran in forum General Tech Discussion
    Last Post: 04-03-2010, 08:16 PM
  4. Oil drain plug
    By SlowM90 in forum General Tech Discussion
    Last Post: 12-22-2009, 12:05 PM
  5. Jumpy idle when IAT is plugged in?
    By ninnyGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2009, 02:54 PM
