Thread: "Tried" removing exhaust tips
Results 1 to 18 of 18
  1. #1 "Tried" removing exhaust tips
    GT Level Member fri3dchick3n's Avatar
    Alaska
    Tried to remove my exhaust tips so I can clean them up a little bit. I tried uncrewing the bolts to the ring that holds it tight. But I was twisting the bolt instead and broke both of them :O. What are they called so I can go maybe buy some new ones without looking like an idiot.
    8f3e602a.jpg picture by fri3dchick3n - Photobucket
    27742fe1.jpg picture by fri3dchick3n - Photobucket
    5dc99ab7.jpg picture by fri3dchick3n - Photobucket
    99 GTP: 3.4'' MPS, Overkill PCM, Intake, Catless SD Headers, TransGo Shift Kit, 180º Thermostat, Flipped Dog Bones
  2. #2 Re: "Tried" removing exhaust tips
    St. Louis
    Those are called muffler clamps
  3. #3 Re: "Tried" removing exhaust tips
    Delaware, OH
    or ubolt clamps
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  4. #4 Re: "Tried" removing exhaust tips
    Alaska
    Thanks! Lol
  5. #5 Re: "Tried" removing exhaust tips
    Grand Island, Nebraska
    yep just cut them rings off and go buy some clamps from your local auto parts store. I did the same thing.
  6. #6 Re: "Tried" removing exhaust tips
    Alaska
    OMG! I just cant get these clamps off! They are rusted on there so bad! Should I just bust out the sawzall on there candy asses?
    f2b14d22.jpg picture by fri3dchick3n - Photobucket
    96c4b014.jpg picture by fri3dchick3n - Photobucket
    f91fe2d2.jpg picture by fri3dchick3n - Photobucket
    UPDATE: Bought a metal grinding disc, cut the welded bracket, cut the ring twice opposite of each other and the ring came off easily. Exhaust tip was a little harder to take off, just opened up the flaps and pulled side to side for a few minutes and popped off, you may fly back a few inches I did >.>
  7. #7 Re: "Tried" removing exhaust tips
    i would, then some big channel lock pliers, to twist em off. lots of salt on the roads up there in Alaska huh???? lol
  8. #8 Re: "Tried" removing exhaust tips
    Houston
    Quote Originally Posted by fri3dchick3n View Post
    LOL...I just wiggled it as far out as I could and then stood on it and bounced.
  9. #9 Re: "Tried" removing exhaust tips
    Alaska
    LOL, I actually flew back a foot or two but that made me laugh.
    So I cleaned them up with a copper wire brush atachment for a drill, cleaned it up almost the best I could.
    I dont really like the way they look lol. Too shiny/bright. Doesnt look good on an all black car.
    Anyone paint there exhaust tips black? I think I am going too!
    578d7596.jpg picture by fri3dchick3n - Photobucket
    d53292d8.jpg picture by fri3dchick3n - Photobucket
  10. #10 Re: "Tried" removing exhaust tips
    Pennsylvania
    The inside of your tips will be black from carbon within a week. Just leave it. I'd put a layer of clear paint on the lip, though, after a good polish.
  11. #11 Re: "Tried" removing exhaust tips
    Say whaaaa?
  12. #12 Re: "Tried" removing exhaust tips
    Houston
    Leave em off and go ghost tip...spoooky!
  13. #13 Re: "Tried" removing exhaust tips
    for however long i ran my car with no tips just because i was cheap and lazy, it looks kinda stupid. put tips on it.
  14. #14 Re: "Tried" removing exhaust tips
    LOL.. you could have saved time and effort. Put them back on and they'll look the same in a few weeks.
  15. #15 Re: "Tried" removing exhaust tips
    Alaska
    I think your right lol. Oh well, I had nothing else to do!
  16. #16 Re: "Tried" removing exhaust tips
    Stop on over. I've got tons of projects for ya to do.
  17. #17 Re: "Tried" removing exhaust tips
    Alaska
    I have a bunch of mini projects that need to be done to this car, its beat up. I guess its not Alaska proof lol. But if I ever cross your path, I guess I can fill up your tires with air or something
  1. Chug at start, "bouncing" tach when key turned to "on"...
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 10:50 PM
  2. removing exhaust tips
    By Bakerdd in forum General Tech Discussion
    Last Post: 01-28-2010, 09:44 PM
