Thread: Sputtering on 98 gtp with no engine light code
Results 1 to 4 of 4
feonnixxx Sputtering on 98 gtp with no... 01-07-2011, 05:41 PM
JLAudioEclipse Re: Sputtering on 98 gtp with... 01-22-2011, 03:50 AM
redgrandprix77 Re: Sputtering on 98 gtp with... 03-14-2011, 12:38 AM
feonnixxx Re: Sputtering on 98 gtp with... 04-12-2011, 06:12 PM
  1. #1 Sputtering on 98 gtp with no engine light code
    minneapolis, mn
    I have a 98 GP GTP and every time the boost kicks in the supercharger sputters and decreases power. I am having to keep performance shift on in order to give myself enough power to pass someone. when its cold (i live in mn) it seems to run just fine but as soon as the engine slightly warms up it starts sputtering. it doesnt matter what gear im in but in high gear when the super kicks in at low rpm's it starts to really affect my power, it starts jumpin a little bit. the messed up thing is the check engine light doesnt come on even if i pound on the gas (trying to cause a light to come on) anybody know what might be causing this?
  2. #2 Re: Sputtering on 98 gtp with no engine light code
    SE Level Member JLAudioEclipse's Avatar
    Jan 2009
    Clarkston,mi
    Get access to a scanner or hook up with someone in your area to scan each individual cylinder for misfires. I bet you come to find that you have a weak coil, cut plug wire, or a plug that is over gapped/cracked/fouled. Hope this helps
    Ryan C
    PB 13.11@103.5 1.95 60ft
    Mods: 100% Stock l67 from 03, Home Ported gen 3, Home ported T/B, Home made belt rap kit, 2.8 pulley, pacesetter headers, Hot air intake, e85, autolight plugs, Stock catback, Ryan Carter Tune ( Myself ).
  3. #3 Re: Sputtering on 98 gtp with no engine light code
    atlanta
    did you find out what it is cause I have the same issue with my 1999 gtp.
  4. #4 Re: Sputtering on 98 gtp with no engine light code
    minneapolis, mn
    i just did a tune up (new wires and plugs) and found that one of my wires had been chewed on by a squirrel or something. once i did that the sputtering went away. I was having issues with my MAF sensor as well which was just a corroded wire, rewired a new connector on there and works GREAT
  1. Sputtering and P0300 code
    By grngt97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2010, 02:12 PM
  2. Help with 2000 GTP -- engine sputtering
    By cartman68 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2009, 10:07 AM
  3. Check engine light on. Code: P0481
    By glomgold in forum General Tech Discussion
    Last Post: 03-22-2009, 04:10 PM
  4. *ERROR CODE INSIDE* Installed new PCM - Service engine light is on
    By Freebeer187 in forum General Tech Discussion
    Last Post: 11-23-2008, 07:05 PM
  5. Engine Check Light Code List
    By 04CompG in forum General Tech Discussion
    Last Post: 09-18-2008, 12:50 PM
