Thread: is it right
Results 1 to 16 of 16
  1. #1 is it right
    GTX Level Member 94grandprix's Avatar
    Jul 2010
    Crandall, Georgia, United States
    can anybody post a pic of their 3.1 liter engine area were the oil cap and intake are,ive got a piece of gasket sticking out and we just replaced it,so is it right or not and could it be answer to the whistling and loss of power
  2. #2 Re: is it right
    i have a 3.1 but i dont have a pic right now ill get one tomaro
    do you have a pic of what your talking about?
  3. #3 Re: is it right
    Jul 2010
    it wnt let me upload it
  4. #4 Re: is it right
    u try photobucket?
  5. #5 Re: is it right
    Jul 2010
  6. #6 Re: is it right
  7. #7 Re: is it right
    there it is
    i dont think thats subpost to be like that
    ill check mine and see
  8. #8 Re: is it right
    no its fine mines like that too
  9. #9 Re: is it right
    GT Level Member sportred04's Avatar
    Feb 2010
    indianapolis
    its just extree gasket material.
    Quote Originally Posted by Warbeaver View Post
    I loved it when Bill Cosby said, " if you don't want white folks to look at you different, pull your damn pants up and learn to dress yourself"
  10. #10 Re: is it right
    Jul 2010
    what could be the noise right in that area and when i move that piece it whistles louder and when i mash the gas and hold it,it isnt as loud
  11. #11 Re: is it right
    Feb 2010
    indianapolis
    a little more descriptive please
  12. #12 Re: is it right
    try spraying some carb cleaner around the area, if you have a leak the idle will jump up, then you know if its a leak.
  13. #13 Re: is it right
    yea you may have tore a hole there when you ripped it off..try this^
  14. #14 Re: is it right
    Jul 2010
    there wasnt anything tore or ripped off and the piece im talking about is the extra gasket material,i gently pulled it down and it makes the whistling noise louder
  15. #15 Re: is it right
    St. Louis
    Then you have a massive vacuum leak. Time to re-do the intake gasket.
    The whistling gets less noticeable when you rev it up and hold it because manifold vacuum decreases as the rpms increase.
    Make sure when you reinstall the new gasket that it doesn't slip and get misaligned. I usually put a dab of black rtv on the corners and let it skin up for a few minutes, then set the gasket in place and go from there. This minimizes the chance of the gasket moving.
  16. #16 Re: is it right
    While you are at it.. you might want to consider the age of those original plug wires.
