Thread: Will longer vac lines cause loss in Vacuum?
Results 1 to 7 of 7
  1. #1 Will longer vac lines cause loss in Vacuum?
    Houston
    So I wanted to move my Vac line, from my TB to my EVAP purge valve, off of my supercharger. It required me to put a longer line on. The new line is probably 4-5 inches longer. Would this cause my vacuum to go from around 16 inHg to around 13.6 inHg?
    This is the hose before:
    This is after:
  2. #2 Re: Will longer vac lines cause loss in Vacuum?
    no.
    but a leak would
    stock cam should net you 20-21 in Hg.
  3. #3 Re: Will longer vac lines cause loss in Vacuum?
    Houston
    Is that at a cold start up and idle? With it warmed up, it used to be around 18inhg and now warm its 16inhg. The only thing I changed was the vac line. And its been hotter outside since the change...(not sure if that'd have anything to do with it)
  4. #4 Re: Will longer vac lines cause loss in Vacuum?
    depends, when the car is HIGH idle the hg will be lower.
    mines at like -17.9 ish, then once warm its -20.1
    but now that its warmer, it dont go into high idle much anymore
  5. #5 Re: Will longer vac lines cause loss in Vacuum?
    Houston
    Hmmm..so with the temp increase outside my vac should be higher. You said with a stock cam, Matt....what if it's not stock?
  6. #6 Re: Will longer vac lines cause loss in Vacuum?
    depends on the cam.
    what cam are you running?
  7. #7 Re: Will longer vac lines cause loss in Vacuum?
    Houston
    I dont know...and I dont know how to find out without takin it out.
  1. vacuum lines
    By Danbo004 in forum General Tech Discussion
    Last Post: 04-15-2011, 10:51 PM
  2. Vacuum lines
    By rtorres422 in forum Shops and Community Heroes
    Last Post: 05-24-2010, 10:18 PM
  3. vacuum lines
    By shawn3091 in forum General Tech Discussion
    Last Post: 01-11-2010, 10:15 AM
  4. Different Vacuum Lines...
    By Iron Indian in forum General Tech Discussion
    Last Post: 08-17-2009, 12:47 AM
  5. longer SS brake lines (fbody brakes)
    By UR LOSN in forum Brakes/Suspension/Chassis
    Last Post: 03-30-2008, 02:38 PM
