Thread: Fuel Tank Sensor going bad
Results 1 to 20 of 34
  1. #1 Fuel Tank Sensor going bad
    Kansas
    So for about a week now my car's fuel gauge has been going up and down.
    I know how much gas I have though because I just reset the DIC every time I fill up.
    I want it fixed so I was going to order Fuel Tank Meter Sender/Connector from gm parts direct.
    My question is if I pull the pump out is there anything I could try cleaning then reinstalling to see if it works better to save some money?
    SOLD 1999 GT Silvermist TS
  2. #2 Re: Fuel Tank Sensor going bad
    Charles City, IA
    Nope, just have to replace it.
    SMGPFC Two Nipple General
  3. #3 Re: Fuel Tank Sensor going bad
    Kansas
    Thank you for the fast response
  4. #4 Re: Fuel Tank Sensor going bad
    Jan 1970
    Maquoketa, Iowa
    You could try looking at it and cleaning. It's simple to take out, just take the bucket out and it's right there, fairly simple to detach and unplug it or replace.
  5. #5 Re: Fuel Tank Sensor going bad
    Kansas
    Well ordered it..going to try and clean it first then see if that helps and if it works ill return the part.
  6. #6 Re: Fuel Tank Sensor going bad
    GT Level Member sasquatch094's Avatar
    cleveland
    This code should of popped up or just stay in your computer until you scan it.. p0463
    I just bought a Snapon scanner the other day and just hooked it up to my car for sh*tsandgiggles, and come to find that damn code.
    tell me how everything goes if you could.
    Fosho... bucket??? isnt there a hole in the floor board?
  7. #7 Re: Fuel Tank Sensor going bad
    Kansas
    I have a aeroforce.. no codes and also my tuner never showed anything.. I will check in a couple hours for that code when i go back out for more tuning.
    Hole in the trunk is what I have heard.
    Ill be sure to update this subject. Cant put new sensor in until this weekend when i go home.
  8. #8 Re: Fuel Tank Sensor going bad
    cleveland
    hey man, so in the mean time of my last post, ive found out an assload of information about this thing. lol
    heres a nice video for ya
    BonnevillePRO.com • View topic - VIDEO: How to change fuel sending unit
    The hole in the floor is going to make this a breeze. and also youll need this
    GM#15824379 FUEL SENDER ~GM Vehicles-Suv's-Trailblazer - eBay (item 120684733768 end time Feb-20-11 12:59:50 PST)
    The ebay one is 25+ dollars cheaper then the dealer price. watch the videos youll understand
    25bucks compared to a new sending unit of 500 bucks..
  9. #9 Re: Fuel Tank Sensor going bad
    Kansas
    Thanks for the videos... That should help.
    But I paid 119 bucks for the part off of gm parts direct.
  10. #10 Re: Fuel Tank Sensor going bad
    cleveland
    yikes.. lol Hopefully i can get this part by this weekend and install it. ill let you know how this one goes. Maybe youcan save some money
  11. #11 Re: Fuel Tank Sensor going bad
    Kansas
    Replaced sensor today.. very easy to do less then 30 min
  12. #12 Re: Fuel Tank Sensor going bad
    cleveland
    I replaced mine yesterday, it was pretty easy to do. although i had a really hard time getting the metal ring and the sending unit out, it was like my access hole in the trunk wasnt big enough.
    To bad you couldnt have saved a couple bucks on those parts...
  13. #13 Re: Fuel Tank Sensor going bad
    MA
    I thought i would post pictures of an old fuel level sensor and a new fuel level sensor so you can see what happens to them.
    OLD FUEL LEVEL SENSOR 67000 MILES ON CAR
    NEW FUEL LEVEL SENSOR YOU CAN SEE HOW MUCH LONGER THE CONTACTS ARE.
  14. #14 Re: Fuel Tank Sensor going bad
    cleveland
    After changing the level senders in my car, im getting a mysterious evap code. cleared it once and now its back on.. hmm
  15. #15 Re: Fuel Tank Sensor going bad
    Kansas
    probably didnt seal your tank up right happened to me i just took out the pump put it back in better and all was good
  16. #16 Re: Fuel Tank Sensor going bad
    cleveland
    seal?? like the metal ring? man that thing was a PITA to get back in there! i had a hell of a time getting the whole sending unit out as well.
  17. #17 Re: Fuel Tank Sensor going bad
    Kansas
    The seal as in the rubber ring that goes around the pump
  18. #18 Re: Fuel Tank Sensor going bad
    Glen Burnie, Md
    i just did the same process today. Spoke with a friend of mine, who stated that "GM fuel pumps" is notorious for this issue. Said to take a pencil eraser, and rub the contact points. Going to see if this works or not. and then i'll order the new piece.
  19. #19 Re: Fuel Tank Sensor going bad
    cleveland
    Quote Originally Posted by Gafford44 View Post
    never even seen a rubber ring... opps
  20. #20 Re: Fuel Tank Sensor going bad
    MA
    Quote Originally Posted by sasquatch094 View Post
    O ring goes between sensor assembly and tank it's more like a large rubber grommet than an o ring
  1. Drop Fuel Tank
    By roundbox52 in forum General Tech Discussion
    Last Post: 07-15-2023, 08:43 PM
  2. Fuel tank door latch?
    By grandjim in forum Introductions/Noob Questions
    Last Post: 09-25-2010, 11:12 AM
  3. change fuel tank, now no start
    By nypilot21 in forum General Tech Discussion
    Last Post: 08-02-2010, 12:10 PM
  4. How many gallon fuel tank
    By kjclawson in forum General Tech Discussion
    Last Post: 11-13-2009, 06:30 PM
  5. fuel tank capicity
    By whiteknuckle in forum General Tech Discussion
    Last Post: 01-19-2009, 07:44 PM
