Thread: Advice needed
Results 1 to 20 of 20
  1. #1 Advice needed
    SE Level Member ksteb88's Avatar
    Manitoba
    Hey, I got an 02 GTP Coupe Supercharged. Found the other day there is a crack in the exhaust pipe under the driver/passenger seat. I am going to be replacing the whole set-up but didnt know what to go with. Was thinking about a glasspack system thats really low sounding idle and gets higher pitched when I accelerate. Let me know what worked for you and what to stay away from. Thanks
    02 GTP Supercharged Coupe; Black With Crome; Glasspack exhaust; Mods In The Works--> Intake, Lights, Stereo
  2. #2 Re: Advice needed
    Florida
    Just get either a muffler shop to fab you up a cat-back, with the longest glasspack you can find for a resonator, and 2 decent muffers, orrr get the ZZP Catback with a resonator.
    Our cars sound like crap with just glasspacks, and sound really raspy without a resonator. Also, stay away from chambered mufflers..
    Borla mufflers are the tits.
    Magnaflow and flowmasters arent bad either.
  3. #3 Re: Advice needed
    MO
    Contradicted yourself. Flowmasters are chambered mufflers.
    But he's right, make sure you have either a res or glasspack, and a set of non-chambered mufflers.
    <brandonl2000> LMAO D!!
  4. #4 Re: Advice needed
    Donating User Odi's Avatar
    Chicago South Suburbs
    stock mufflers + glasspack res = tits.
  5. #5 Re: Advice needed
    Florida
    As long as the whole exhaust isnt rusted out, just do that.
  6. #6 Re: Advice needed
    Florida
    Meh, I do what I want. A friend of mine in St. Augustine has some flowmasters on his GT, and it did sound good, until about 5k rpm...But that pretty much stands for any muffler...
    Didnt know they were chambered. Learn something new everyday. XD
  7. #7 Re: Advice needed
  8. #8 Re: Advice needed
    Manitoba
    I got it up on a lift last night and it turns out that it is not a leak in the pipe but actually a rusted out hole in the resonator the size of a pop bottle lid. When I was under there I was under there I took a long look at it and got an idea. I am gonna cut the resonator out, pipe it from the cat then put a y pipe in and then put 2 performance mufflers and tips in. What do you think of that idea?
  9. #9 Re: Advice needed
    SE Level Member RICE KILLER's Avatar
    st. paul mn
    if you are going to go that route run 3in pipe with a the longest 3in glaspack you can find for a resonator to a y pipe that reduces it to 2.5in then go with some magnaflows single or dual straight throurghs, depending on how loud you want it. this is what i run on mine it sounds great, 0 rasp with a nice deep tone.
    2000 Daytona Pace car, SD Hood, Xp cam, Ported Heads, Gen V, North Star, Headers, ZZP stage 2 Intercooler, 3in Exhaust, and custom tune
  10. #10 Re: Advice needed
    3in exhaust is over board. If you want to save money go with 2.5 exhuast.
    Or just remove your stock res and replace it with a glasspack, then leave the rest of the exhaust alone, aftermarket mufflers on these cars sound like crap.
  11. #11 Re: Advice needed
    Florida
    You absolutely want a resonator of some kind..either a legit resonator, or a long ass glasspack, otherwise you will drone, and rasp pretty bad.
    2.5" pipe is more than fine. 3" is pretty much only usefull for very high power builds.
  12. #12 Re: Advice needed
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    put a glasspack in place of the res and thank us later
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  13. #13 Re: Advice needed
    Manitoba
    Yeah I went and talked to my mechanic today. I am going to be cutting out the resonator and replacing it with a glasspack. So what your saying though is I don't need to worry about mufflers? And would tips make any noticable difference other then visually?
  14. #14 Re: Advice needed
    Florida
    Tips will just be for asthetics. You can get mufflers if you want it to be louder, but just go ahead and get the glasspack installed, and see how you like the sound. If you want it louder, then get a pair of mufflers.
  15. #15 Re: Advice needed
    Manitoba
    Yeah thats what I am likely gonna do
  16. #16 Re: Advice needed
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    cherrybomb is worth it
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  17. #17 Re: Advice needed
    Manitoba
    Got the car back from the shop. Has the glasspack in the place of the res with stock pipes and mufflers. Sounds exactly the same as it did before I found the leak in the res. So tonight I am cutting the mufflers off and gonna put on some performance mufflers on in a few days.
  18. #18 Re: Advice needed
    Go back up there and get that u-bend taken out of you didn't do that...that is the 1st order of business as it is probably the poorest design on the entire car.
    As for mufflers...don't get anything chambered.
  19. #19 Re: Advice needed
    Manitoba
    Wow, I cut the mufflers out of the car and what a difference. It sounds frickin' beastly, really low at an idle then when I accelerate it gets louder and a higher pitch. There is about 2ft from where I chopped it to the end of the bumper. Should I put mufflers or just pipe it into a set of tips?
  20. #20 Re: Advice needed
    put mufflers in.
    It gets quieter in the cabin if you have the turn downs or have the exhaust get into the molded tip part of the bumper.
  1. CD player instal, parts needed, advice needed
    By timmaayy2323 in forum Audio, Security & Visual Electronics
    Last Post: 02-21-2011, 08:53 PM
  2. Advice needed
    By psav in forum General Tech Discussion
    Last Post: 02-18-2011, 10:25 AM
  3. Advice needed
    By ksteb88 in forum Visual/Body Modifications
    Last Post: 07-29-2010, 10:04 PM
  4. advice needed
    By PMave in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-17-2010, 06:52 PM
  5. Hello all! Advice needed!
    By jeremylester in forum Introductions/Noob Questions
    Last Post: 08-18-2009, 07:13 PM
