Thread: Gas Mileage
Results 1 to 20 of 31
  1. #1 Gas Mileage
    GT Level Member Remnant King's Avatar
    Nov 2010
    Michigan
    I be done almost everything I can to TRY and improve my gas mileage. I replaced the resonator with a straight pipe since it had a hole in it, I did a tune up, I sea foamed the car, and yesterday I changed the ecg valve or something like that. And after all that its still showing up 10-13 MPG...wtf.
    I understand a used cars needs repairs, and I am willing to put money into it as long as it improves, not sets me back. Its really frustrating, and the valve is now making some weird noise D:
  2. #2 Re: Gas Mileage
    I'm betting vacuum leak...or a shot o2 sensor...do you have any check engine lights?
  3. #3 Re: Gas Mileage
    Florida
    Ok first thing do you notice your exhaust sounds a lil loud and weird? glasspack that muh. Then the next thing would be to check is fuel filter, fuel pump, fuel lines for leaks, bad o2 sensor, and your cat could be clogged affecting your fuel mileage.whatelse is there... Do you heavy foot it all the time or most times? that too.
  4. #4 Re: Gas Mileage
    Nov 2010
    Michigan
    I DID have a Check Engine Light, but that was the valve, which I replaced. How would I know if its a shot o2 sensor or vacuum leak?
    Not sure if it's the exhaust, but there's a lot of loud and weird noises D:
    I changed the fuel filter, and the pump IS making noise. Havent really looked into the lines for leaks, neither the o2 sensor. How would I check if the cat is clogged? I rarely ever heavy foot it unless I need to, and there's no way I heavy footing it as much as where it drops down THAT much. I go into the car this morning to warm it up. What started at 13 mpg, ended at 3.1 mpg by the time the car was done warming up...D:
  5. #5 Re: Gas Mileage
    Nov 2010
    Marine City MI
    Quote Originally Posted by Remnant King View Post
    Of course your MPG isn't good your sitting still. Also check your tire pressure.
    99 GTP, ZZP MPS 2.9 pulley, GenIII supercharger ported & polished, machined intake W/ stage 2 intercooler, XP Cam,ZZP fuel rails, 42.5 injectors, Wizard CAI, custom headers, 3 inch downpipe, into dynomax muffler,180 stat, Northstar TB, 85mm MAF, ZZP trans, 3.29 gears, input shaft and torque converter, stock heads W/Ls6 springs.
  6. #6 Re: Gas Mileage
    Indiana
    Just my 2 cents...try resesting the dic? I know mine was awful low and not matching what i was hard figuring until I reset it and now its better. So maybe it just hasnt been reset for a long time?
  7. #7 Re: Gas Mileage
    Nov 2010
    Michigan
    Thanks for the suggestion, but I've reset it almost every time I would pump gas.
  8. #8 Re: Gas Mileage
    GT Level Member 40th GP's Avatar
    Utah
    Quote Originally Posted by BlackSun View Post
    What he said. How far had you driven it to get the 13 mpg? These don't have an 'actual' mpg, it is averaged. If you filled up and then went home and parked it and ended up there with 13 then of course you only had 3 after sitting there warming up. You are using gas and going nowhere, so your mpg's while warming up are zero. It only needs 10-15 seconds of warming up on a cold day before you can drive it (carefully until it reaches operating temp).
    As mentioned, you need to check how many gallons it took you to drive the miles you got out of that tank. If you do a lot of excess idling and warming up and only drive around town you will never get good mileage. My DIC usually shows about 30, but I drive 99% of the time on the highway, and even then I find it to be about 5-10% optimistic.
  9. #9 Re: Gas Mileage
    Nov 2010
    Michigan
    Quote Originally Posted by 40th GP View Post
    That honestly really helps, I always give the car 5-10 mins of warming up only because literally EVERYONE says you have to wait until the temperature hits like 180 before driving -__-
    I changed out the plugs and wires about a month ago so I doubt that could be the problem.
    Other than that, I'll just have to calculate it myself and see what I get. Thanks a lot to every one of you for the help, I really appreciate it.
  10. #10 Re: Gas Mileage
    SE Level Member akaMatt's Avatar
    Nov 2010
    Hudson Valley, NY
    have u actually tried dividing the miles driven by the gallons bought?? i never reset mine, and its actually pretty close... i get 21.x in mixed driving/commuting...
    2004 Monte Carlo SS/sc: Red/Silver, Intense PCM, K&N, Magnaflow DP, Res Delete, 18" ARE Casino wheels, Drilled/Slotted Rotors...
  11. #11 Re: Gas Mileage
    Nov 2010
    Michigan
    Quote Originally Posted by akaMatt View Post
    That, I havent done no. I'll have to try doing that the next time I fill up.
  12. #12 Re: Gas Mileage
    Wichita
    Check your spark plugs and spark plug wires. If any of those are bad that will affect your mileage.
  13. #13 Re: Gas Mileage
    Iowa
    The DIC isnt always correct even resting it, my Silverado normally says 13.8-14.5 and I regularly get 16-18, not sure with the Prix, havent even had it a week so we have yet to run a full tank through it
  14. #14 Re: Gas Mileage
    Indiana
    reset you avg MPG and see if it improves because sometimes the DIC can glitch and not show correct MPG just reset by holding the reset button down and report back
    1997 Pontiac Grand Prix GTP SUPERCHARGED Black with Blackouts
    1996 Pontiac Bonneville Under Construction. Soon to be supercharged along with a little extra :P
  15. #15 Re: Gas Mileage
    Nov 2010
    Michigan
    Bringing this thread back up because I finally got the chance to calculate it the way it's supposed to be. I filled up the car with 11.2 gallons, and I drove 168 miles with it. After the calculations, it gives me exactly 15 miles to the gallon, which is even LOWER than what the DIC is showing :\
    It's getting a little frustrating to be honest haha.
    Only thing I can think of to do would be replacing the O2 sensors, cleaning/replacing the catalytic converter, or a vaccum leak which would throw a code right?
    Just a recap, this is what I have done to the car already:
    Replaced Spark Plugs and Wires
    Replaced a valve (ECG or something)
    Replaced the shot Resonator with a straight pipe
    Seafoamed the car
    Used Injector Cleaner
    Replaced Fuel Filter
  16. #16 Re: Gas Mileage
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    What type of driving are you doing? If its highway then something is really wrong, but if its around town then its nothing noteworthy.
    On my commute to high school I got around 14 MPG. My drive (one way) was 1.5 miles with lots of hills, 3 stop signs, and one light. My dad's srx with a brand new engine got around 9 with the same drive.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  17. #17 Re: Gas Mileage
    Nov 2010
    Michigan
    I am usually just driving from my house to college, or around town.
    I only go on the highway either once or twice a week.
  18. #18 Re: Gas Mileage
    Newnan, GA
    Then my guess is that it should be around 17 MPG, so your not too far off.
  19. #19 Re: Gas Mileage
    Nov 2010
    Michigan
    If that's the case, it's not too bad, but it is when everyone else seems to be averaging 19 mpg >_>
  20. #20 Re: Gas Mileage
    Newnan, GA
    All depends on the driving. You probably idle your car to warm it up more than most, and I fight Atlanta traffic. Others who float around town with the low speed cruise and stop lights will get better mileage.
  1. BAD gas mileage
    By tc300 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-19-2011, 01:51 PM
  2. bad gas mileage
    By Joe m in forum General Tech Discussion
    Last Post: 02-03-2010, 02:17 PM
  3. Better mileage on an old V8 than a GTP LoL!
    By Juanmiguel in forum The Rant Forum
    Last Post: 01-28-2010, 09:26 PM
  4. Gas Mileage
    By cincygoat in forum General Tech Discussion
    Last Post: 01-28-2010, 12:08 AM
  5. Gas Mileage
    By nikkigpgt00 in forum General Tech Discussion
    Last Post: 11-28-2009, 11:57 PM
