Thread: ZZP 8 Rib Pulley
Results 1 to 13 of 13
  1. #1 ZZP 8 Rib Pulley
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    My ZZP MPS finally arrived. Unfortunately, it's made for an 8 rib belt. I reviewed the auction on which I purchased; it says nothing about being an 8 ribber.
    So...are these units all sold as 8 rib now, such that 2 ribs will simply be left virgin when coupled to my 6 rib supercharger belt? Or will I be sending this back and waiting another 4 weeks...
    My concern being with the offset for the abovementioned case.
    Thanks.
  2. #2 Re: ZZP 8 Rib Pulley
    Donating Users
    South Deerfield, MA
    They all come 8 rib. Only use the 6 you need.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  3. #3 Re: ZZP 8 Rib Pulley
    Nov 2010
    Marine City MI
    My 2.9 pulley is 8 but the rest of my accessories are 6 you should be fine.
    99 GTP, ZZP MPS 2.9 pulley, GenIII supercharger ported & polished, machined intake W/ stage 2 intercooler, XP Cam,ZZP fuel rails, 42.5 injectors, Wizard CAI, custom headers, 3 inch downpipe, into dynomax muffler,180 stat, Northstar TB, 85mm MAF, ZZP trans, 3.29 gears, input shaft and torque converter, stock heads W/Ls6 springs.
  4. #4 Re: ZZP 8 Rib Pulley
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Make sure you sit the belt so that the two ribs FURTHEST FROM THE BLOWER are left unused, any other combination will lead to your belt not being aligned correctly.
    For all your 3800 needs:
  5. #5 Re: ZZP 8 Rib Pulley
    Joliet, IL
    Quote Originally Posted by copgtp View Post
    i was told directly from zzp to place the belt in the middle.
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  6. #6 Re: ZZP 8 Rib Pulley
    Charles City, IA
    The belt will sit where it wants. On my 3.5 it was on the inside, old 3.4 outside, 3.2 middle, new 3.4 middle.
    SMGPFC Two Nipple General
  7. #7 Re: ZZP 8 Rib Pulley
    Joliet, IL
    Quote Originally Posted by TheOtherNick View Post
    mine stays where i place it lol
    00 Silvermist GTP
  8. #8 Re: ZZP 8 Rib Pulley
    Dec 2010
    Canada
    Thanks.
    It's quite stupid that ZZP does not make 6 rib quick-change pulleys.
  9. #9 Re: ZZP 8 Rib Pulley
    why make two sets of pulleys when an 8 rib works on both a 6 rib and 8 rib setup?
  10. #10 Re: ZZP 8 Rib Pulley
    Dec 2010
    Canada
    Why spend more money on material and more time to manufacture?
  11. #11 Re: ZZP 8 Rib Pulley
    because two sets of pulleys will cost way more than one set with a couple extra grooves.
  12. #12 Re: ZZP 8 Rib Pulley
    Dec 2010
    Canada
    More parts to stock, I agree with you on that Bio. If we ventured a guess though, what is the ratio of 6 rib to 8 rib pullies? Maybe 10:1. That's where I'm going with this....
  13. #13 Re: ZZP 8 Rib Pulley
    im sure it is even bigger than that for 6 rib setups. out of the time ive spent around this scene ive seen less than 10 people with 8 rib setups.
