Thread: Does anybody know where the IAC sensor or TB screen is located??
Results 1 to 7 of 7
  1. #1 Does anybody know where the IAC sensor or TB screen is located??
    SE Level Member nickdemio's Avatar
    STL
    I have a 01 Grand Prix GT-3.8 and wanna know where the IAC sensor and TB screen are located..so i can clean or replace???? Im fairly new to this & dont have to much mechanical knowledge..Help!!! (Picz would be very helpful)
  2. #2 Re: Does anybody know where the IAC sensor or TB screen is located??
    Apr 2009
    Wausau, Wisconsin
    TB screen is in the TB, IAC sensor is a little plug thing that is a twist and pull to remove and its on your intake
  3. #3 Re: Does anybody know where the IAC sensor or TB screen is located??
    STL
    Thanx for the insight!! Does anybody have picz of the IAC sensor on the intake?? Cause i see 3 sensor's in that area
  4. #4 Re: Does anybody know where the IAC sensor or TB screen is located??
    Theres only one sensor on the intake tubing.
    the rest are on the TB.
  5. #5 Re: Does anybody know where the IAC sensor or TB screen is located??
    GrandPrix Junkie
    St. Louis
    He seems to be asking where the IAC (Idle Air Control) valve is at, not the IAT (Intake Air Temp.).
    The IAC is one of those 3 sensors on your TB. It looks like this and is held on with 2 bolts...
    I wouldn't replace the TB screen, but just clean the entire TB w/ the appropriate cleaner (not carb or brake cleaner) and call it done. The butterfly in the TB gets gummed up after years and sticks sometimes. Also clean the passages for the IAC, etc... Get a new TB to UIM gasket as well or you will have leaks.
  6. #6 Re: Does anybody know where the IAC sensor or TB screen is located??
    Hagerstown,Md
    IAC isnt in the intake. Its the sensor on the TB that looks like the above picture
  7. #7 Re: Does anybody know where the IAC sensor or TB screen is located??
    STL
    Good lookign out FordMan!! the picz were definitely helpful.
    2001 GP GT
  1. Where is the coolant temp sensor located?
    By usetaboost in forum General Tech Discussion
    Last Post: 11-26-2010, 06:34 PM
  2. Hello...and where is my oil drain plug located?
    By mbable in forum Introductions/Noob Questions
    Last Post: 04-06-2009, 12:18 PM
  3. Replacing a speed sensor, where are they located?
    By McCalley08 in forum General Tech Discussion
    Last Post: 01-24-2009, 04:17 AM
