Thread: HELP! radiator support replacement
Results 1 to 10 of 10
  1. #1 HELP! radiator support replacement
    GT Level Member 04BlackComp_G's Avatar
    Apr 2008
    Rockport, ME
    Has anyone on here done it before? I have to replace mine after my blunder a few nights ago. I was on my way to a call and when I went to slow down to park I hit a dip and hit the bottom of the support and now my radiator is bent in a bit not to mention a dent in my subframe. Replacing the subframe is not a problem, but I know the rad support my be an issue. Any insight on this is greatly appreciated.
    2009 G8 GT #1311 of 1949:CTS-V front/Camaro rear brakes, Solo Performance axle back exhaust
    2006 GP GXP: ZZP catback, k&n intake, retrofit headlights, cts-v brakes
    2007 Escalade ESV:family hauler
  2. #2 Re: HELP! radiator support replacement
    St. Louis
    Is it something a big slide hammer could pull out? Might get away with just pulling it back into shape instead of hassling w/ replacing the entire thing. I do believe that the rad. support is spot welded in place at factory. Never taken one of these apart that far though.
  3. #3 Re: HELP! radiator support replacement
    Apr 2008
    Rockport, ME
    It's possible that it could be pulled out. Just thinking of it in a safety sense. I'll take a better look at it when the snow clears up again.
  4. #4 Re: HELP! radiator support replacement
    I'd pull out the rad and get a block of wood and BFH. Hit the wood many times to slowly reshape the support .
  5. #5 Re: HELP! radiator support replacement
    Apr 2008
    Rockport, ME
    You are the man. That will save me a trip for now, at least until I come down for the sub-frame and header install we talked about on nepontiac! Thanks Bill.
  6. #6 Re: HELP! radiator support replacement
    We are doing a subframe too? I'm supposed to go get one huh?
  7. #7 Re: HELP! radiator support replacement
    Apr 2008
    Rockport, ME
    Yup I just gotta give you the money, and I have to finish cutting and welding the speed daddys. I'm slightly out of your delivery range otherwise I would have done that aspect myself.
  8. #8 Re: HELP! radiator support replacement
    No biggie.. we'll be pulling two of the four bolts anyhow. After that it's the control arms, a 10mm for the ps lines, and the 4 nuts holding the mounts to the drivetrain.
    It's cake..
    Remind me though.. you are Jim the guy scheduled for the 26th right? I'll make sure and get the sub this or next week.
  9. #9 Re: HELP! radiator support replacement
    Apr 2008
    Rockport, ME
    Nope I'm Aaron, we haven't scheduled yet. I gotta find time off or it would have to be a weekend thing. My biggest issue is finding the time to finish the headers.
  10. #10 Re: HELP! radiator support replacement
    Ok.. cool. Got a couple things happening. Just realized theres three header installs this week. I'm practicing for when you are ready.
  1. Quality Replacement Radiator
    By Burgundyman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-14-2010, 09:01 PM
  2. Needs some GPF support and votes!
    By Swash in forum Off Topic Discussion
    Last Post: 10-07-2010, 02:58 PM
  3. Radiator replacement
    By PolynesianMedic in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-03-2010, 03:59 AM
  4. Radiator Replacement on my '97 GT
    By VGPGT in forum General Tech Discussion
    Last Post: 01-15-2010, 05:37 PM
  5. Radiator and Water Pump replacement 95 Prix SE Coupe
    By Soultempter in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-20-2009, 12:08 AM
