Thread: scan parameters
Results 1 to 10 of 10
  1. #1 scan parameters
    Apr 2009
    freehold,ny
    i just installed my aeroforce gauge today and i dont know if the parameters that are being shown are good or bad does anyone know the parameter meanings or a link i'm showing 16.4 for my long trim and a/f 14.9 are these good or not thanks!!
  2. #2 Re: scan parameters
    Hagerstown,Md
    16.4 is a vac leak, And AFR off the Aeroface isnt accurate at all. its just reading commanded AFR which means DICK
  3. #3 Re: scan parameters
    Apr 2009
    freehold,ny
    where do you get this info about the numbers being good or not
  4. #4 Re: scan parameters
    Hagerstown,Md
    Quote Originally Posted by sca555 View Post
    From tuning cars for 6 years, and reading tuning forums, Like this one>HP Tuners Bulletin Board - Powered by vBulletin
  5. #5 Re: scan parameters
    Apr 2009
    freehold,ny
    well i should i read the long trim at idol at on the go cause on the go its 16.4 at the highest with it being wot
  6. #6 Re: scan parameters
    Hagerstown,Md
    Yeah 16.4 means you have a vacuum leak
  7. #7 Re: scan parameters
    Apr 2009
    freehold,ny
    how can i perform a vaccum leak test to find out where it is
  8. #8 Re: scan parameters
    Hagerstown,Md
  9. #9 Re: scan parameters
    Apr 2009
    freehold,ny
    thanks that helps out alot i will let you know the results of the test and im also seeing misfires and kr up to 7* on the gauge what could this mean
  10. #10 Re: scan parameters
    Apr 2009
    freehold,ny
    well i did the vacuum leak test and did not find anything, do local shops do these and if so whats the price range
  1. pcm scan
    By chrisLB in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2010, 10:32 PM
  2. take a look at this scan!
    By RICE KILLER in forum PCM Tuning
    Last Post: 07-15-2010, 08:23 PM
  3. kr scan
    By GMPUNK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2010, 08:17 AM
  4. My first scan... wth is going on?
    By PonchoDvr4Lfe in forum PCM Tuning
    Last Post: 10-22-2009, 09:55 AM
  5. Why cant I see parameters
    By deangtp in forum PCM Tuning
    Last Post: 04-14-2008, 06:03 PM
