Thread: should i service high milege transmission
Results 1 to 7 of 7
djwright1980 should i service high milege... 03-13-2011, 09:02 PM
postalc38 Re: should i service high... 03-13-2011, 09:53 PM
GAFF Re: should i service high... 03-13-2011, 11:48 PM
BillBoost37 Re: should i service high... 03-14-2011, 07:02 AM
Lion29GTP Re: should i service high... 03-14-2011, 04:14 PM
djwright1980 Re: should i service high... 03-14-2011, 07:40 PM
Sularus65 Re: should i service high... 03-18-2011, 05:57 PM
  1. #1 should i service high milege transmission
    SE Level Member djwright1980's Avatar
    tennessee
    My 2000 gtp has 160k miles mostly highway. And uneware if trans has ever been serviced.just wondering if I should just leave alone or could do a drain and fill? Trans works good just fluid looks brown and used.
  2. #2 Re: should i service high milege transmission
    SE Level Member postalc38's Avatar
    Brant, Michigan, United States
    How brown does it look? If it looks closer to motor oil then trans fluid, most people will suggest not to touch it.
    I wouldn't do a flush, but if you do anything I'd drop the pan, change the filter and possibly the gasket (gasket is usually included with filter.)
    Changing the gasket is not required if you have the original re-usuable gasket.....You can usually tell by the appearance of 2 lines that run along the gasket. Here is an example.
    You must replace the gasket if it is not the original gasket OR if it is leaking.
    The site where I found that image also has a write-up for dropping the pan and changing the filter. That link is located HERE.
    2000 GP - 157K (DD/Crash damaged project)
    1995 Olds Aurora L47 - 222K
  3. #3 Re: should i service high milege transmission
    Kansas
    Quote Originally Posted by postalc38 View Post
    Most people recommend not doing a flush like postalc stated.
    Follow what he said replace the filter and go on with normal driving.
    SOLD 1999 GT Silvermist TS
  4. #4 Re: should i service high milege transmission
    Pan drop service. Filter and fluid. In about 3-6 months do it again and you'll have most of the old dead fluid out.
  5. #5 Re: should i service high milege transmission
    Jan 2009
    Long Island
    Mine has 144K, I replaced all the solenoids , filter and flushed it myself.
    Can shifts smooth. I love the thought of all clean oil.
  6. #6 Re: should i service high milege transmission
    tennessee
    Thanx for the input guys I will probably drop the pan and replace the filter and add accorddingly.
  7. #7 Re: should i service high milege transmission
    Feb 2010
    N.C.
    I would drop the pan, change the filter and refill with dex VI. if you plan on keeping the car a bit, think about doing the shift improvement kit. May add a some length to the life of the trans.
    J
    Most people spend their entire lives wondering if they made a difference in the world; Marines don't have that problem.
    -President Ronald Regan
  1. Comments Wanted - 05 Comp G Service Stability/Service Traction
    By JD05CompGTP in forum General Tech Discussion
    Last Post: 03-13-2012, 08:21 PM
  2. Transmission Service
    By cowmilker08 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-19-2010, 11:08 PM
  3. Customer service at dhp
    By goldgp in forum PCM Tuning
    Last Post: 03-31-2010, 11:25 AM
  4. Better Gas Milege
    By Cal Cross in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-25-2009, 10:56 PM
  5. Service ABS soon
    By gahris in forum Brakes/Suspension/Chassis
    Last Post: 06-01-2009, 10:49 PM
