Thread: One messed up spark plug
Results 1 to 16 of 16
KeithGTP03 One messed up spark plug 03-06-2011, 06:06 PM
Madness Re: One messed up spark plug 03-06-2011, 06:08 PM
KeithGTP03 Re: One messed up spark plug 03-06-2011, 06:13 PM
Scottydoggs Re: One messed up spark plug 03-06-2011, 06:52 PM
Mike Kopstain Re: One messed up spark plug 03-06-2011, 06:42 PM
gtpinsc Re: One messed up spark plug 03-06-2011, 06:44 PM
KeithGTP03 Re: One messed up spark plug 03-06-2011, 06:55 PM
tc300 Re: One messed up spark plug 03-07-2011, 02:32 PM
MidnightBlue Re: One messed up spark plug 03-06-2011, 06:59 PM
gtpinsc Re: One messed up spark plug 03-06-2011, 06:59 PM
KeithGTP03 Re: One messed up spark plug 03-06-2011, 07:18 PM
MidnightBlue Re: One messed up spark plug 03-07-2011, 08:14 AM
whiney Re: One messed up spark plug 03-07-2011, 03:38 PM
GMGUY Re: One messed up spark plug 03-11-2011, 01:01 PM
Bio248 Re: One messed up spark plug 03-07-2011, 03:12 PM
01gpgt01 Re: One messed up spark plug 03-07-2011, 07:31 PM
  1. #1 One messed up spark plug
    Houston
    Explains the misfire on #6. Whats weird is that it would only misfire at idle and not while accelerating or just cruising. What do yall think? Chipped piston? Possible faulty spark plug? Its not smashed in like it should be if it were a chipped piston.
  2. #2 Re: One messed up spark plug
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    Yikes!!, Hummm, where did the rest of it go? Sad part is, we all know.
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  3. #3 Re: One messed up spark plug
    Houston
    Im hoping it just magically disappeared..lol. I blew out the cylinder with an air hose, but nothing came out. Im wondering if its in my oil pan.
  4. #4 Re: One messed up spark plug
    its not in the oil pan....it went out the exhaust valve.
    i'd do a compression test and hope the valve's still tight, most of the time the valve gets beat up when little chunks of metal pass through them.
    and scope the piston if you can.
  5. #5 Re: One messed up spark plug
    SE Level Member Mike Kopstain's Avatar
    Chicago, IL
    That appears to just be plug failure. The whole insulator is missing! Of all the chipped pistons I've seen, I've never once seen debris remain in the cylinder.
    Thinking about shopping with ZZP or the other guys? - Order with us instead and we'll give you a 5% off coupon code for your next order! Click here to learn how!
    Like us on Facebook!
  6. #6 Re: One messed up spark plug
    Jul 2008
    sumter,south carolina
    get a bore scope and take a peek... i had a tip broken off due to chipped piston before.
    may i ask why u are running double plats?
    02 GTP with mods 05 GP for DD
  7. #7 Re: One messed up spark plug
    Houston
    I put those in 4 yrs ago...I just put in some iridium, and new wires and the misfires from #6 are gone. And quite a bit of difference in power with that cylinder firing. Just weird that it didnt throw a code.
  8. #8 Re: One messed up spark plug
    GTP Level Member
    springfield IL
    any thing wrong with running double plats or plats..???
    just changed my plugs and wires yesterday.. pretty sure i got ac delco plats
    really didnt see the point of paying 8.99 a plug for iridium
  9. #9 Re: One messed up spark plug
    Banned
    Sioux Falls, SD
    I also have had a spark plug that looked like that, and i tore the engine apart and i had a chipped piston.
  10. #10 Re: One messed up spark plug
    Jul 2008
    i was just wondering.. most of us run some sort of copper plug.
  11. #11 Re: One messed up spark plug
    Houston
    Quote Originally Posted by miker56 View Post
    Crap, I kinda figured but I thought the electrode would be smashed in if that were the case.. I was hoping for a defective plug.
    I went to get some NGK V power but they only had like 2. And I didnt feel like drivin all over for em, so I just got iridium.
  12. #12 Re: One messed up spark plug
    Banned
    Sioux Falls, SD
    here are the pictures of mine
  13. #13 Re: One messed up spark plug
    swift current,sask.
    Maybe it's just me, but that looks like a huge gap?
  14. #14 Re: One messed up spark plug
    SE Level Member GMGUY's Avatar
    Dec 2010
    West Jordan Utah
    I have seen on motors that run to lean...
  15. #15 Re: One messed up spark plug
    nothing wrong with running platinums. however, the concensus is that if youre modding your car youre best off with cheap copper plugs because they perform the best. you just have to change them ever 15k miles or so.
  16. #16 Re: One messed up spark plug
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Chunkaroo
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  1. Spark plug
    By zildjian102 in forum General Tech Discussion
    Last Post: 03-01-2011, 02:48 AM
  2. spark plug gap range is best?
    By fst in forum Turbo
    Last Post: 01-31-2011, 08:50 AM
  3. Spark Plug Help
    By STP5593 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2010, 10:15 PM
  4. Spark Plug Replacement??
    By LuckyBambu in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2010, 08:06 PM
  5. Spark plug suggestions?
    By projectGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-17-2009, 08:43 AM
