Thread: Polyurethane motor mounts
Results 1 to 11 of 11
  1. #1 Polyurethane motor mounts
    SE Level Member PALMCASTER GT1's Avatar
    PALMDALE CA
    WHAT'S UP YOU GUY AND GIRLS ??? I NEED HELP FINDING A COMPANY THAT HAS GOOD PRICES ON MOUNTS FOR MY GT1 , ALL FOUR . I KNOW OF ZZ PERFORMANCE , AND 3800 , ARE THERE ANYMORE ???
  2. #2 Re: Polyurethane motor mounts
    Florida
    wbody store as well.only $30, thats where im gettin mine from
  3. #3 Re: Polyurethane motor mounts
    we only have 2 motor/trans mounts
    1 for the motor and 1 for the trans
    zzp sells them, wbody store sells them too
  4. #4 Re: Polyurethane motor mounts
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    i think he is talking about dog bones to
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  5. #5 Re: Polyurethane motor mounts
    Oct 2008
    Calgary, Alberta
    I installed a energy suspension lower engine mount
    Some drilling requiredas well as shims (oversized nut and some washers) but I installed a energy suspension mustang transmission mount as the lower engine mount (4.1104), and may try the same for the transmission mount with a gm trans mount (3.1108) smaller than the mustang mount.
    For the engine mount I used shims to bring up the base to the same elevation as the origonal bolt holes, just bolted down to the bottom pan of the engine mount (2 holes drtilled) I drilled out 2 holes matching the upper's spacing as well to allow me to ream out one hole, and offset the other allowing the poly mount to be easily replaced if required for future use/ replaced by the same style rubber mount if I didn't like the feel.
  6. #6 Re: Polyurethane motor mounts
    stay out of the lounge with parts/technical questions, please.
  7. #7 Re: Polyurethane motor mounts
    PALMDALE CA
    my bad i ment the two mounts and top bushings
  8. #8 Re: Polyurethane motor mounts
    PALMDALE CA
    cool bio , its been awhile since i've been here , i had to do some time in county jail but im back now.
  9. #9 Re: Polyurethane motor mounts
    PALMDALE CA
    @ bio248 , i'll get the hang of it , its been a lil bit since i played with my computer .
  10. #10 Re: Polyurethane motor mounts
    you should try and stay out of jail. just a suggestion.
  11. #11 Re: Polyurethane motor mounts
    Pennsylvania
    You mean the upper mounts? Everyone says that Intense makes the best poly for them, since it's not as hard as ZZP's, so less teeth rattling.
  1. motor mounts
    By Chizzler in forum Brakes/Suspension/Chassis
    Last Post: 05-23-2010, 08:10 AM
  2. Motor mounts
    Last Post: 05-14-2010, 08:13 PM
  3. Motor Mounts
    By trailshredder in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-24-2010, 02:43 PM
  4. motor mounts
    By dmoney01 in forum General Tech Discussion
    Last Post: 03-01-2009, 01:35 PM
