Thread: windshield wiper
Results 1 to 5 of 5
  1. #1 windshield wiper
    GT Level Member backinblackgtp's Avatar
    Nov 2009
    centereach, NY
    having a problem with my passenger side windshield wiper/ driver side as well i guess, seems to only have ONE speed (fast) and it will go up and down 3 or 4 times then get stuck in the middle of the window until i press the wiper button again.... in addition, my passenger side wiper has decided not to move more then 3 inches from the resiting position.... is this just the wiper motor? or is it more, and is it an easy fix?
  2. #2 Re: windshield wiper
    you may just need to tighten up the bolts on the wiper arms, can you hear the motor working still when the arms stall out? if so i bet its the arms not being tight.
    if not that, the wiper trans or motor or switch maybe bad, you'll have to open up the cowl and check it out.
  3. #3 Re: windshield wiper
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    yeah there should be little small rubber pieces covering the nut for the windshield wiper arm. its like a 1/2 9/16 or 13 or 15mm or something like that lol tighten up a little bit and they should be good to go. just follow the wiper arm to the end and u'll see it.
  4. #4 Re: windshield wiper
    Nov 2009
    centereach, NY
    alright thanks guys ill try it out
  5. #5 Re: windshield wiper
    Jan 2009
    Long Island
    how about when it works and park in the middle 12 o"clock????
  1. Windshield Wiper Motor
    By gpgt98 in forum General Tech Discussion
    Last Post: 12-31-2011, 12:13 AM
  2. Windshield Wiper Help
    By Liquifire in forum General Tech Discussion
    Last Post: 01-17-2010, 03:19 PM
  3. Windshield Wiper Pump
    By sirschuster in forum General Tech Discussion
    Last Post: 04-21-2009, 05:50 PM
  4. Windshield Wiper Question
    By BADAZGTP in forum General Tech Discussion
    Last Post: 08-20-2008, 10:56 PM
  5. windshield wiper help
    By maybe_memories in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2008, 02:48 PM
